Prelude Shift linkage ?
Old Feb 16, 2007 | 07:43 AM
kornerk12's Avatar
Default Prelude Shift linkage ?
Is it all the same length 4th gen, 5th gen base and SH ? I know you need the shifter for the 4th gen if u have 4th gen linkage and 5th gen shifter with 5th gen linkage.
Old Feb 16, 2007 | 08:39 AM
92hondalude's Avatar
Default Re: Prelude Shift linkage ? (kornerk12)
yes you can use the 4th gen cables on a 5th gen
Old Feb 16, 2007 | 10:07 AM
98vtec's Avatar
moderator emeritus
from what i could tell, the lengths are the same between 4th gen and 5th gen. the shifter plates just mount a little differently to the car and the shift cables mount differently between the 4th and 5th gen. base and SH are identical.
Old Feb 16, 2007 | 12:44 PM
prelude1897's Avatar
Everything is the same between the Base and SH, but the 4th Gen shifter has a different plate so you'll need to modify that to make it work...Which I also believe an Accord shifter will work as well
pprowler6
Jan 16, 2007 08:37 PM
hamadiscool
Dec 13, 2006 10:37 PM
flight50
Jul 13, 2005 10:19 AM
EM2Civic
Oct 4, 2004 10:24 AM
