is the vtec controller worth it
Old Feb 19, 2007 | 09:25 PM
skylude23's Avatar
Default is the vtec controller worth it
I heard that if you get a vtec controller you can make your vtec kick in early but i heard that if you do that it lowers your top end speed. so is it only worth it in a 1/4 mile race and put it back to normal on a highway race?
Old Feb 19, 2007 | 09:30 PM
ethereal2pt2's Avatar
Default Re: is the vtec controller worth it (skylude23)
do a search for vafc and you'll find your answer. this topic has been covered numerous times. but i will say it's all in the tune.
Old Feb 20, 2007 | 01:30 AM
jdmh22a1's Avatar
i got the buddy club Vcon...vtec controller...its aight..i mean i got it dirt cheap...so...yah...but i heard the apex 1 was good bc..it adjusts everything from fuel to spark...mine is just power ground...and wired into the vtec on computer...but i try to keep it as close to stock bc i heard it puts alot of stress on the motor..but just look into..it ask other ppl...AND search
Old Feb 20, 2007 | 05:47 AM
ludecz's Avatar
Actualy with the Vafc you're kind of limited, it doesn't adjust spark timing!
For the money you can have Hondata or Crome with a lot of features.
Adjusting Vtec will not lower your top end speed.
Old Feb 20, 2007 | 06:15 AM
prelittlelude's Avatar
the short of it is no, a controller that just changes vtec engaugement point is stupid. You need something that can adjust fuel and spark as well to see any gains.
Old Feb 20, 2007 | 06:22 AM
M2B4's Avatar
Default Re: is the vtec controller worth it (prelittlelude)
get chipped with a street tune.
Old Feb 20, 2007 | 06:23 AM
godslayer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skylude23 &raquo;</TD></TR><TR><TD CLASS="quote">I heard that if you get a vtec controller you can make your vtec kick in early but i heard that if you do that it lowers your top end speed. so is it only worth it in a 1/4 mile race and put it back to normal on a highway race?</TD></TR></TABLE>
Damn, there must be an influx of VTEC controllers on Ebay because this is the 1000th time this has been asked this week.
VTEC is NOT Nitrous. VTEC is a way to internally adjust backpressure to allow greater output throughout the powerband of the motor, thats it. Swithching lobes and fully lifting all the valves (VTEC kick as you refer to it) at 2000 RPM does nothing but f*ck up the powerband.
Old Feb 20, 2007 | 06:29 AM
M2B4's Avatar
Default Re: is the vtec controller worth it (godslayer)
^^^ exactly. VTEC is not an instant "xx" HP. Placement of vtec engagement is what yields you the HP. placing it low w/o a real dyno tune wont add that "xx" hp to your bottom end.
Old Feb 20, 2007 | 06:35 AM
prelude_h22vtec's Avatar
the lowest vafc lets you put the vtec engagement is 3k. i used to have one and i tried a lot of different engage point and its rediculously slow like that.
VTEC_1229
Jul 19, 2016 07:13 PM
vteclife
Jan 3, 2008 08:49 AM
killa_lude
Aug 1, 2003 07:01 PM
ahunt01
May 9, 2003 08:02 AM
00GSR
Jun 20, 2001 10:20 AM
