Headgasket modification
Old Feb 16, 2007 | 07:59 AM
kornerk12's Avatar
Default Headgasket modification
I know how some of you only run certain layers of the HG to up compression. What layer do you remove or do you only run one layer ? If so which layer ?
Old Feb 16, 2007 | 08:02 AM
94Vtecluder's Avatar
Default Re: Headgasket modification (kornerk12)
On a oem honda hg people usually remove the middle layer. I'm not sure you want to remove more than that.
Old Feb 16, 2007 | 08:04 AM
kornerk12's Avatar
Default Re: Headgasket modification (94Vtecluder)
Oo ok I thought i remembered someone saying that they ran one layer but im not positive.
Old Feb 16, 2007 | 08:05 AM
Missing Gears's Avatar
you HAVE TO remove 2 lyers, the middle and an outer. otherwise it wont seal.
you only use 1 outer layer.
Old Feb 16, 2007 | 08:07 AM
kornerk12's Avatar
Default Re: Headgasket modification (Missing Gears)
it doesnt matter which out side correct ?
Old Feb 16, 2007 | 08:08 AM
i always use the bottom layer only beacause the top layer has "UP" cut out of it.
Old Feb 16, 2007 | 08:11 AM
kornerk12's Avatar
No leaks ? And you toque the headbolts to spec correct no tighter ?
Old Feb 16, 2007 | 08:18 AM
we have done it several times w/o any problems or leaks. i always tq the headbolts to factory spec.
Old Feb 16, 2007 | 08:19 AM
yes, 72ft/lbs
also i always thought peeps remove one layer. whatever
Liquidgsr
Apr 26, 2006 10:20 PM
giff74
Mar 19, 2005 02:09 AM
ekdriven
Mar 8, 2005 08:00 AM
iam7head
Sep 25, 2002 07:05 AM
non-VTEC
Mar 16, 2002 04:20 PM
