cams?
Old Feb 12, 2007 | 12:34 PM
russianswty's Avatar
Default cams?
Who makes some good cams for the h series motors?
Old Feb 12, 2007 | 12:36 PM
nonvteclude's Avatar
Default Re: cams? (russianswty)
take a look in the faq's lots of info. search alittle. and you dont need to make 3 different threads at the same time to ask 3 different questions.
Old Feb 12, 2007 | 12:38 PM
kaoss_11's Avatar
B A N N E D
crowers
Old Feb 12, 2007 | 12:44 PM
fast_honda's Avatar
Default Re: (kaoss_11)
JUN, haha (good luck)
Old Feb 12, 2007 | 01:01 PM
98vtec's Avatar
moderator emeritus
Default Re: (fast_honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast_honda &raquo;</TD></TR><TR><TD CLASS="quote">JUN, haha (good luck)</TD></TR></TABLE>
w3rd.
cam choice depends on alot of things like compression, stroke, power goals...etc
if you are asking these questions, do not go out and just buy a cam because it is cheap or because someone on the other side of the computer tells you one is better than another.
example:
do not buy an aggressive cam with stock compression. You will more likely than not be unsatisfied with the results. NA isnt like boost. In order to have a GOOD build, each part must work well together.
Youlose1305
14
Jul 10, 2006 12:26 PM
The Destroyer
12
May 30, 2006 02:57 PM
EKB18C97
17
May 2, 2006 03:30 PM
Edward
Nov 3, 2005 02:59 PM
SuperSteve
Jul 31, 2003 09:31 AM
