Rebuilt Engine
Old Feb 15, 2007 | 08:58 PM
ninety7GSR's Avatar
Default Rebuilt Engine
Im looking at buying a `98 Prelude and had a question about it for you guys. Its drivin by a lady who has had it since 27k miles. It currently has 82k on it. I guess about 4-5k ago it was using oil so she took it to the dealer where it has been serviced from new. They ended up contacting Honda and rebuilding the engine for no charge to her. They said it was a manufacture defect or something. I not totally sure what all was done but I know it received new rings and rod bearings as well as a valve job. My question is, should I be nervous about this or would you guys consider it a good thing. I just get nervous about it even though it was performed at a Honda dealer. Help me out....
Old Feb 15, 2007 | 09:00 PM
vinuneuro's Avatar
Default Re: Rebuilt Engine (ninety7GSR)
Should be fine. Contact the dealer and find out exactly what was done.
Old Feb 15, 2007 | 09:08 PM
ninety7GSR's Avatar
Default Re: Rebuilt Engine (vinuneuro)
ya I plan on having it checked out complete at that dealer. I want a full compression and leak down test done on it to make sure the rings were done right. It was driven by a grandmother for the lad almost 60k so I know it wasn't due to a kid smashin on it...
Old Feb 15, 2007 | 09:09 PM
TOO MUCH TORQUE's Avatar
sometimes a rebuild will not help with oil usage. sometimes require a new block.
Old Feb 15, 2007 | 09:14 PM
ninety7GSR's Avatar
Default Re: (TOO MUCH TORQUE)
Why would a new block help? I understand if it had 200k on it and the pistons had scored the cylinder walls to the point that the rings could not seal to them, but not at 82k. A leak down or compression test should be able to tell if the rings aren't getting a good seal on the cylinder wall.
butch1175
Feb 12, 2013 06:06 PM
FK00GSR
Oct 8, 2009 07:12 PM
H22Luda
Nov 13, 2004 11:20 AM
Frook
Jun 3, 2004 05:35 PM
redintegra
Sep 27, 2002 01:20 PM
