H22 Header
Old Feb 15, 2007 | 02:27 PM
bigdogg41's Avatar
Default H22 Header
I'm looking for a quality header. H22 motor in an eg chassis, the car is only roadraced. If this helps my post the motor has ITB'S, stage 3 cams ,on C16
Old Feb 15, 2007 | 04:01 PM
di rang's Avatar
Default Re: H22 Header (bigdogg41)
HIGH TECH
Old Feb 15, 2007 | 04:33 PM
kb58's Avatar
Banned
try posting in the Prelude group.
Old Feb 15, 2007 | 06:03 PM
luder94-ChrisA's Avatar
Default Re: H22 Header (kb58)
SMSP
Old Feb 16, 2007 | 06:44 AM
1GPlusSH's Avatar
Default Re: H22 Header (luder94si)
SMSP, Rage, RMF(what I'm going with), Hytech, just check around. Some perform better with certain setups; they do worse in others. They all are $700+, but they are well worth the money. There's a recent post with a dyno of a few different high end headers, but I'm too lazy to search for it right now.
Old Feb 16, 2007 | 08:32 AM
GtechPro's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigdogg41 &raquo;</TD></TR><TR><TD CLASS="quote">I'm looking for a quality header. H22 motor in an eg chassis, the car is only roadraced. If this helps my post the motor has ITB'S, stage 3 cams ,on C16</TD></TR></TABLE>
You'd get the best gains with a custom header (SMSP, RMF) but they are a bit expensive.
A Greddy header with the 2.5" collector mod will also render decent gains and it's much cheaper. That's what I'm about to do.
Old Feb 16, 2007 | 09:35 AM
98vtec's Avatar
moderator emeritus
your application is dying for a custom spec'd header.
Old Feb 16, 2007 | 10:48 AM
cpforyou's Avatar
Default Re: H22 Header (98vtec)
I used a Hytech, and I went from 216WHP to 233WHP!
That's because I originally had a restrictive DC Sports Header.
Hytech has two versions of H22A header, depending on how much power you plan on making. You might need the second version of it.
I was happy with mine.
Old Feb 16, 2007 | 10:52 AM
98vtec's Avatar
moderator emeritus
Default Re: H22 Header (cpforyou)
well if he is on c16, i'd think that he has high compression and enough to support the huge cams and ITB's. stepped pipes ftw
honda_12V
Nov 2, 2012 10:45 AM
slim9300
Mar 26, 2006 06:46 AM
eg:R
May 26, 2004 10:46 AM
Myh4tch
Mar 27, 2004 09:05 AM
ranta18
Sep 27, 2003 04:25 PM
