car doesn't start
Old Feb 16, 2007 | 11:26 AM
707the89fu's Avatar
Default car doesn't start
i have a 1993 Honda Prelude Si
and wouldn't start
i have replace the PGM-FI Relay or the Fuel Pump relay
but nothing had happen
i think it might be the Starter Cut Relay
does any one
have a pic of what it look like.
or where it might be at.
thanks
ro
Old Feb 16, 2007 | 11:27 AM
Hawkze_2.3's Avatar
Default Re: car doesn't start (707the89fu)
Does it turn over at all?
Old Feb 16, 2007 | 11:38 AM
rickyh22's Avatar
I can help you answer that if the car powers up..... if all the lights power up and you have replace the fuel pump then two things can be wrong with it....1) the timing belt if the timing belt had snap your car will not be able to start and 2) if the timing belt is did not snap, then it could be the starter..... the starter has 2 wires and 1 of the wire always come lose all your have to do is plug it back in.... that what happen to my lude before....see if that help... pm me if it did....
Old Feb 16, 2007 | 11:46 AM
Ludster's Avatar
does it just crank when you try and start it? just a click? does ur fuel pump "prime"?
Old Feb 17, 2007 | 06:46 PM
707the89fu's Avatar
Default Re: (Ludster)
here the sh
the Starter Cut Relay is getting no power
i check the fuse for it No2 7.5A
and the light didn't come on
(light tells you if you get power it a tool i use)
so i thinking of run a wire from the PGM-FI Relay
to the Starter Cut Relay with a fuse in the middle
but before this all happen
it took me two or three tries just to start it
i thought it was the spark plugs
so the next day i started it up
but when i put the gas it started to die out
evertime i had touch the gas it will die
then i replace the PGM-FI Relay it just didn't want to catch spark
but when it would i will put the gas it die
now it just turn over
it sound like it not getting any spark
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ludster &raquo;</TD></TR><TR><TD CLASS="quote">does it just crank when you try and start it? just a click? does ur
fuel pump "prime"?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">Does it turn over at all?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rickyh22 &raquo;</TD></TR><TR><TD CLASS="quote">I can help you answer that if the car powers up..... if all the lights power up and you have replace the fuel pump then two things can be wrong with it....1) the timing belt if the timing belt had snap your car will not be able to start and 2) if the timing belt is did not snap, then it could be the starter..... the starter has 2 wires and 1 of the wire always come lose all your have to do is plug it back in.... that what happen to my lude before....see if that help... pm me if it did....</TD></TR></TABLE>
i can see my timebelt and it not snap the plug is in there
thank you for all your help
but maybe someone got my right answer
Modified by 707the89fu at 9:39 PM 2/17/2007
Old Feb 17, 2007 | 10:57 PM
ludetunerz's Avatar
Default Re: (707the89fu)
So it turns over? Could be the ign. coil.
Old Feb 18, 2007 | 06:28 AM
mdpc20653's Avatar
coil if it hasn't been changed
Old Feb 18, 2007 | 10:22 AM
707the89fu's Avatar
Default Re: (ludetunerz)
ya the coil was never change
but could it cause it not to get any power to the
fuse for the
CHONCH2
14
Jan 21, 2010 10:26 AM
heeltoehonda
Dec 5, 2009 11:39 AM
91rexhf
10
Dec 27, 2008 05:06 PM
3M TA3
Jan 20, 2008 10:35 AM
gutted-dx
20
Jun 18, 2005 12:03 PM
