Deck Height?
Old Dec 30, 2007 | 04:29 PM
rohec04's Avatar
Default Deck Height?
what would be the deck height of type s pistons on h22a4 engine?
Old Dec 30, 2007 | 08:47 PM
98vtec's Avatar
moderator emeritus
Default Re: Deck Height? (rohec04)
you mean compression height?
pistons dont change the deck height. decking and milling do.
Old Dec 31, 2007 | 09:22 AM
bluedlude's Avatar
Default Re: Deck Height? (98vtec)
deck height is actually the distance from the crank centerline to the deck surface. if you are trying to find clearance from the piston top to the deck surface you are going to have to measure it directly or you can guesstimate based on known values (clearance = deckheight - (stroke/2) - rod length - compression height of piston)
so from reading the FAQ you can get all the values you need for a guess
deck height of H22 = 8.643"
stroke/2 = (90.7/2) / 25.4 = 1.7854"
rod length = 5.633"
compression height = 1.221"
clearance = 8.643 - 1.7854 - 5.633 - 1.221 = 0.0036"
that is the clearance you would have in a perfect world. meaning if your block has never been decked and all other components are perfect. hope this helped.
Old Dec 31, 2007 | 01:14 PM
98vtec's Avatar
moderator emeritus
Default Re: Deck Height? (bluedlude)
ah, i knew it didnt sound quite right when i posted it. i should practice what i preach.
JarrettL
Honda S2000
Jun 14, 2012 03:09 PM
JarrettL
11
Jun 8, 2012 03:10 PM
W!d3b0dYr3X
Jul 7, 2011 11:28 PM
dc2_poojan
Jul 5, 2011 12:30 PM
wickedEFguy
Nov 12, 2003 07:26 PM
