Weird Ignition Problem
ok this is hard to explain...so i'll start from the beginning
last week i was driving my car, and all of a sudden my gauges(tach, speedo, temp, gas, and clock) would just turn off, then turn back on. probably happened over a period of 3 seconds. My car would also loose all power, basically shutting down.
fast foward to tonight...
i went to start my car like normal, it WOULD start, but as soon as the key returned to the "on" position, it would turn off (as if i turned the car off). i can start the car, and it will turn over, just not stay started in the "on" position. though i can keep it running if i hold the key is a little toward the start position.
what the hell!
what the hell!
It sounds like your ignition switch is going bad, because I had the same problem, but then it magically disappeared after rebuilding the motor (without changing out the switch, go figure). I'm assuming you have a 95 Prelude (judging by your SN), and I do know there was a recall on the ignition switch for like 97-98 Preludes, but not the 4th gens (as far as I know of). But yeah, I would push the key forward a little and it would kick back when I was having those problems, only mine would die in the middle of the street during rush hour
Anyone else have ideas?
haha its funny i just loked at a threead right before this one and it was the same exact problem https://honda-tech.com/zerothread/2178144
fixed and working
thanks guys!
oh p.s.
this maybe an hour job, turned into a 2 hour job.....the guy that installed my alarm ran 3 wires to the harness, so i had to rewire them back in
thanks guys!
oh p.s.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95greenlude »</TD></TR><TR><TD CLASS="quote">fixed and working
thanks guys!
Ignition switch for sure?
thanks guys!
EF_LSVtec
10
Jan 27, 2017 04:36 PM
