4ws problems!!
Old Jan 3, 2008 | 05:41 PM
rch022's Avatar
Default 4ws problems!!
Ok so today me and my buddy attempted to fix my 4ws since its been not working completely for over a month. We successfully removed the 4ws ECU and followed the writeup on how to re-solder the possibly loose connections. After reinstalling and starting her up, the 4ws light remained on. Any other ideas about what this could be?
Old Jan 3, 2008 | 06:21 PM
rch022's Avatar
Default Re: 4ws problems!! (rch022)
bump
Old Jan 3, 2008 | 06:37 PM
drbenne's Avatar
you should be able to pull a code the same way you check for CEL, except the 4WS will blink.
Old Jan 4, 2008 | 03:44 AM
sean1121's Avatar
Default Re: 4ws problems!! (drbenne)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drbenne &raquo;</TD></TR><TR><TD CLASS="quote">you should be able to pull a code the same way you check for CEL, except the 4WS will blink. </TD></TR></TABLE>
Exactly, you only have to resolder if you're getting codes 60-65. Check the codes.
Old Jan 4, 2008 | 07:31 AM
93sivtec's Avatar
Default Re: 4ws problems!! (sean1121)
Do u pull it from the same jumper under the center console?
Old Jan 4, 2008 | 09:23 AM
shutta's Avatar
yes, do a search for 4ws codes it should be FAQ'd
Old Jan 4, 2008 | 11:56 AM
KleenL's Avatar
Default Re: (shutta)
i can't find 4ws codes for a 4th gen lude. if you have any luck there let me know
Old Jan 4, 2008 | 12:38 PM
93sivtec's Avatar
Default Re: (KleenL)
Ok I just did this and it flashed 7 times,7 long flashes on the cel,is this 4ws code 7 or 70?Thanks
Old Jan 4, 2008 | 12:45 PM
93sivtec's Avatar
Default Re: (93sivtec)
This is just for my Tps(which is cracked on the clip)....does the code flash in the cel area or in the 4ws light?I know it says the 4ws light^^^^^.... but Im almost positive that the 4ws flashed no lights when I jumpered it.So does this mean its probally the soldering points since the 4ws light didnt flash me a code?
Modified by 93sivtec at 2:06 PM 1/4/2008
Old Jan 4, 2008 | 01:53 PM
shutta's Avatar
the 4ws light will blink... watch it.. if it isn't, then you probably shut off your car and restarted it within 5 mins. (this turns on the 4ws light and disables 4ws for some reason). or you were driving aggressivly and the 4ws light came on (for whatever reason it also does this and it talks about it in the hodna manual..)
but dude, if it's always on, then the light WILL BLINK,
Old Jan 4, 2008 | 02:14 PM
Giant_Bean's Avatar
According to the FSM, if you jump the connector and turn the ignition switch on, the light should flash very quickly once, then after a 3 second pause will flash the trouble code. If there is no code, it says to check the 4ws fuse under the dash and the power mirror fuse in the same spot.
Old Jan 4, 2008 | 02:55 PM
93sivtec's Avatar
^^^^^My light is not on,its just not working.I will check again and check the fuses.THanks for the help.
Old Jan 4, 2008 | 03:26 PM
prelude_93vtec's Avatar
did you reset the ecu? you might of fixed the problem but just didnt reset it
Old Jan 4, 2008 | 03:40 PM
KleenL's Avatar
Default Re: (prelude_93vtec)
i unhook the battery and it works for a while but it always quits again sometimes right away sometimes it works for days but i cant find the codes so i just live with it. if you run the car in second gear to the floor unill you hit the rev limiter then shift hard into 3rd that will help you to look away from the light
Old Jan 4, 2008 | 05:58 PM
sean1121's Avatar
4g 4ws info:
http://forums.ntpog.org/showthread.php?t=73
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KleenL &raquo;</TD></TR><TR><TD CLASS="quote">i unhook the battery and it works for a while but it always quits again sometimes right away sometimes it works for days but i cant find the codes so i just live with it. if you run the car in second gear to the floor unill you hit the rev limiter then shift hard into 3rd that will help you to look away from the light</TD></TR></TABLE>
If you want any help I'm in Allen, not that far from Sherman.
Old Jan 5, 2008 | 04:52 AM
94vtirozguy's Avatar
you will find codes for 4ws on this link:
http://www.preludeaustralia.co...21760
kobeRy_si
Honda S2000
Mar 29, 2006 12:35 PM
88backhatch
Aug 17, 2005 08:54 PM
game over
Feb 19, 2005 06:15 PM
BlkGSR
Jun 18, 2003 07:11 PM
MeanGreenEG9
Dec 4, 2002 07:58 AM
