Code 22
Old Dec 25, 2007 | 08:41 AM
Acidcrakker's Avatar
Default Code 22
Okay Im trouble shooting my code 22 today.
So far, everything is connected to the ECU correctly and grounded right. What else could it be?
Old Dec 25, 2007 | 09:06 AM
Giant_Bean's Avatar
Default Re: Code 22 (Acidcrakker)
Do you have a FSM? If you do look at page 6-77, or get a PDF version. It has a very good walk through for that problem
Old Dec 25, 2007 | 09:42 AM
Default Re: Code 22 (Giant_Bean)
Thanks, I need a multi meter to test the oil pressure switch?
Old Dec 25, 2007 | 09:59 AM
xxmastermindxx's Avatar
a new thread for every problem that you're already discussing in your aftermath thread is tarded
you need a meter to test anything electrical. if you are going to be checking for grounds and continuity only, a test light would probably get you by. but a multimeter is much better
and x2 on what the guy above me said, that page in the FSM has an exact, step by step walkthrough to diagnose that CEL.
Old Dec 25, 2007 | 10:22 AM
Default Re: Code 22 (xxmastermindxx)
Yeah thanks. I got the PDF on my computer. Yeah 2 threads is traded. This thread is a whole lot easier for a straight awnser. Thank you.
Old Dec 25, 2007 | 02:34 PM
JasonST's Avatar
U sure ur not just low on oil. Or could be ur oil pressure switch is clogged, take it off and see maybe.
Old Dec 25, 2007 | 02:42 PM
Default Re: Code 22 (JasonST)
I already have, taken it off cleaned it, reinstalled it. Later that night after I did so, I started thowing my code 22. Before that I had no Vtec either. Im hoping its a faulty switch, I read through what it could be in my manual, and its a whole lot of equipment Ill need to get to run all tests. I hope its easy.
Old Dec 26, 2007 | 04:49 AM
vlang29's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acidcrakker &raquo;</TD></TR><TR><TD CLASS="quote"> Before that I had no Vtec either. </TD></TR></TABLE>
So VTEC is working now?
Old Dec 26, 2007 | 04:57 AM
Default Re: Code 22 (vlang29)
No. im hitting Pepboys up for a multimeter after work today.
Old Dec 26, 2007 | 05:05 AM
what does FSM mean?
Old Dec 26, 2007 | 08:31 AM
JasonST's Avatar
Here ya go. hopefully this will save you from lots of headache.
https://honda-tech.com/zerothread?id=889036
Old Dec 26, 2007 | 08:48 AM
Dude you just made my day. All I have to do is Cross the Vtec Oil pressure wire into the Vtec solniod wire and its good to go?
Damn that will be a cake walk.
Looks like Ill be Vtecing tmmorrow.
4.5 quarts of Honda 5w-30w every oil change.
Cheers Jason Thanks
Old Dec 26, 2007 | 12:18 PM
JasonST's Avatar
Yep no problem. Just glad I could help.
Old Dec 27, 2007 | 10:32 AM
It didnt work. I reset the ecu, spliced the wires together and wahlah! Code 22 still there. Any insight as to what the problem is?
Old Dec 27, 2007 | 10:54 AM
Well that blows. I pulled out my ecu and rechecked everything. Okay so, the Vtec wire may have been slightly out of the wiring harness for the ECU. I readjusted everything and turned the car on.
No CEL light. Whoa who!!!
But no Vtec either. I let the car warm up to operating temp, and no vtec. I hit the gas and let it stay at 6k rpm for a good ten seconds. Nothing.
I checked the oil. Its golden brown. Ahh thats so nice. But there is no vtec
I figured Id check to see if theres any cels, just for the hell of it. And guess what I find.
No code 12, 22, 1, or 10.
But a solid cel light. Boo Hoo. This blows monkey *****. Now how am I supposed to trouble shoot this. I think Im gonna start a new thread entitled Solid cel. Only because it will get more attention right away as opposed to my on going novel called the Aftermath.
makerboom
Dec 15, 2014 02:43 AM
Morty
Jun 26, 2008 12:32 AM
endokun83
Dec 4, 2007 12:33 AM
allmotor2.1
Nov 17, 2007 05:01 AM
boost killz
Jul 15, 2001 12:24 PM
