H23 vtec compression?
go check out that deck height thread you started and then figure out what you have to work with. you will have more questions than just this if you do some quick research.
Don't be lazy. Here are the two threads and compression calculator you need.
https://honda-tech.com/zerothread?id=1232811
https://honda-tech.com/zerothread?id=1245658
http://www.c-speedracing.com/h...c.php
Stock head gasket thickness is .026.
tgh22a
Jan 25, 2006 03:34 PM
