throttle body
Old Jan 2, 2008 | 04:59 PM
twiztid00002's Avatar
Default throttle body
whats a good throttle body to get for more power?
Old Jan 2, 2008 | 05:58 PM
Default Re: throttle body (twiztid00002)
would it be better with an s2000 tb or like a skunk2 prelude tb?
Old Jan 2, 2008 | 06:40 PM
cb7tougeracer's Avatar
what mods you have so far and what engine?
Old Jan 2, 2008 | 06:54 PM
Default Re: throttle body (cb7tougeracer)
all i have is a catback on a h22
Old Jan 2, 2008 | 10:11 PM
Edulerp's Avatar
im thinking the s2k because it would be cheaper and iono about carb legal skunk(or is it?)
Old Jan 3, 2008 | 03:12 AM
Acidcrakker's Avatar
Default Re: throttle body (Edulerp)
You really should use the search button a little more often, there also is another post on this board about other TB's.
A new TB wouldn't net that much power. Skunk 2 IM are not Carb legal yet. I think the TB would make it, but it would retarded almost to buy just the TB for a stock application. They are over sized, and you would most likly have to have the IM bored out to the size of the SK2. They are bigger that the IM on H22 being 62 mm.
The better TB replacement would appear to be the th S2K tb, which is 62mm.
The h22 TB is 60 mm.
Old Jan 4, 2008 | 07:31 PM
Default Re: throttle body (Acidcrakker)
so if i got the s2k tb and got my stock IM bored out 2mm then it will fit...and then later get a euroR IM and the s2k tb should fit perfect on it i hear?
Old Jan 5, 2008 | 01:08 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twiztid00002 &raquo;</TD></TR><TR><TD CLASS="quote">so if i got the s2k tb and got my stock IM bored out 2mm then it will fit...and then later get a euroR IM and the s2k tb should fit perfect on it i hear?</TD></TR></TABLE>
Sounds like you like wasting money. Why dont we skip all that bullshit and you can just gimme all the money you have.
You wont need a bored out IM with a s2000 tb. They match up size by size 62mm on each.
Why would you knowingly do that just to get a euro r IM later. Just save up for Eurp R and get the right TB for it. Otherwise I can take paypal
Old Jan 5, 2008 | 06:09 PM
98vtec's Avatar
moderator emeritus
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acidcrakker &raquo;</TD></TR><TR><TD CLASS="quote">
Why would you knowingly do that just to get a euro r IM later. Just save up for Eurp R and get the right TB for it. Otherwise I can take paypal </TD></TR></TABLE>
well isnt that like the pot calling the kettle black.
remember that the s2k throttle does not have an idle screw, but it can be drilled and tapped to use one. It also does not have a fast idle valve either so you will need to loop the coolant line at the thermostat that provides coolant for the FITV and IACV.
BB4_JDM
Mar 8, 2009 06:31 PM
bb_one
Mar 31, 2007 03:09 PM
hamadiscool
Jan 15, 2007 08:37 AM
zumiez007
Jul 29, 2005 06:11 PM
Crono139
Jun 3, 2003 02:12 AM
