Won't Start
Old Jan 2, 2008 | 09:32 PM
krayzieboi213's Avatar
Default Won't Start
I have a 92 Prelude with a 94 H23 block and a 94 H22 head. It has a battery relocation kit so to battery is in the trunk. Now the problem is it won't start. It stalled on me the other day on my way to work. I was driving through a lot of snow because we got dumped on the night before and got over a foot. After it stalled I was rolling so I tried to pop the clutch to start it back up but it just slid because of the snow. Once I stopped it I tried to restart it but it won't start. I had the battery tested and ended up buying a new one. So I put the new battery in and it still wouldn't start. It won't even turn over. It tried to turn over a couple times but most of the time I get nothing from the starter. It doesn't even make a sound. There is a small sound coming from behind the motor. Sounds like a small electrical motor running but it only does it when I try to start it. So please if you have any idea what the problem is please let me know. Its my only transportation so I need it for work.
Old Jan 2, 2008 | 09:48 PM
jahlive's Avatar
Default Re: Won't Start (krayzieboi213)
Just suggestions from a novice. My prelude was giving the same issues and it turned out to be the igniter in the distributor. They tend to go in cold weather, likewise it could be the ignition coil in the distributor as well. Again you are just going to have to diagnose and trouble-shoot.
Diagnose: take one of the spark plug out, place it on the valve cover to see if you get a spark or not. If you do, try some carb cleaner in the intake manifold to see if you it maybe a fuel issue. If the carb cleaner works it could be a fuel pump. Just some suggestions to get you started.
Old Jan 2, 2008 | 10:29 PM
Default Re: Won't Start (jahlive)
if that was it wouldn't the car still try to crank over?
Old Jan 3, 2008 | 12:13 AM
Acidcrakker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krayzieboi213 &raquo;</TD></TR><TR><TD CLASS="quote">if that was it wouldn't the car still try to crank over?</TD></TR></TABLE>
Yes
Old Jan 3, 2008 | 10:05 AM
waynecoSI's Avatar
Default Re: Won't Start (Acidcrakker)
have you checked your power cable going from the battery to the starter? how are your terminals?have you checked your fuses? i had this problem before. im not sure if this is your problem but its worth a shot.
good luck
Old Jan 3, 2008 | 02:45 PM
jahlive's Avatar
Default Won't Start
Sorry I overlooked where you said it did not turnover. Any luck yet. Dunno, in addition to the other suggestions look into the idea of a bad Main Relay.
Old Jan 3, 2008 | 05:53 PM
How about gauge sizes on the wires you have for the relocation kit, its posible that they are thick enough and at normal ldol dont generate a strong enough current. Also if its been said or not, the ignitor.
Old Jan 4, 2008 | 06:17 AM
mgags7's Avatar
This wouldn't explain why it stalled....but most likely your starter is the problem.
Try hitting it with a heavy, blunt object a few times, hard, but don't break the thing, and then see if it cranks over. If not test to make sure you're getting voltage there from the battery and the solenoid wire, if you are, and it still won't crank, the starter is the problem.
Old Jan 4, 2008 | 08:42 AM
Default Re: (mgags7)
i think it stalled cause my throttle body positioning sensor is out. its not the first time its stalled on me. just the first time it wouldn't restart. as far as the wire gauge bein' the problem i dont't thats it cause i've had the relocation kit for a couple years now. i've hit the starter with a blunt object and got nothing.
Old Jan 8, 2008 | 07:43 PM
Default Re: (krayzieboi213)
ok i had the starter checked and it was fried. so i bought a new one and put it in but the car still won't turn over. it tries to but just won't crank. i'm affraid the motor has seized up. tomarrow i'm gonna try to manually turn the motor by the crank bolt. just curious but how hard should it be to crank the motor over?... should to crank fairly easy or is it tough to do?
SwiftTypeR
Jan 3, 2008 06:46 AM
jorge59la
Sep 16, 2007 06:28 PM
Hatchman98
Apr 23, 2007 03:20 PM
nighttrain33
10
Feb 25, 2007 08:10 PM
90EF8
Jul 14, 2002 09:45 AM
