H23 build
Old Dec 30, 2007 | 10:42 PM
badassCRX's Avatar
Default H23 build
I am in the process of building this H23 for a friend. So far the mods are:
JE 9.0:1 pistons and rings
eagle rods
Kiazenspeed balance shaft removal kit
Greddy kevlar timing belt
king berings
arp head studs
stock valve train
mitu T25 turbo
stock crank
I was wondering what manage ment system or anything else i should have him buy( motor is going into a civic as well)
thanks
Old Dec 31, 2007 | 04:18 AM
PrecisionH23a's Avatar
Default Re: H23 build (badassCRX)
You are building the engine and using a t25 turbo?
Get rid of that thing. It's way entirely too small. Look into AEM or Hondata for your EMS.
Old Dec 31, 2007 | 06:12 AM
RubenPrelude's Avatar
That turbo is waaayyy to small!
Old Dec 31, 2007 | 06:49 AM
Hawkze_2.3's Avatar
Greddy doesn't make an H23 timing belt, only H22. Gates does make a stronger H23 timing belt though...
You also can't stick those forged pistons in without sleeving the block.
Old Dec 31, 2007 | 07:26 AM
waynecoSI's Avatar
Default Re: H23 build (Hawkze_2.3)
yea you def need to have your block sleeved to run forged pistons cause of the FRM of the stock walls. go with a bigger turbo..buddy of mine has a garret fs. im pretty sure its a .57 trim. brand new
Old Dec 31, 2007 | 07:27 AM
cb7tougeracer's Avatar
your building the engine but dont know what EMU to use?
Old Jan 1, 2008 | 08:40 AM
h23prelude's Avatar
i havent heard of this term until i started visiting this forum, what is the "FRM" of the stock cyl walls, and why does that not allow us to run forged pistons? do we have to sleve the block to run Hypereutectic pistons?
Old Jan 1, 2008 | 11:39 AM
95greenlude's Avatar
Default Re: (h23prelude)
^» Search Results
Your search for FRM returned 70 results.
Old Jan 3, 2008 | 10:43 AM
Pilotx1's Avatar
Im building an h23a1 for turbo as well, and havent decided on the engine managment yet either, looking at the hondata s300 or AEM EMS right now. biggest thing im runnung into is a lack of places to have machining work done on the block right now. Ive got a set of new OEM pistons to go in but am looking for an aftermarket alternative thats a little more turbo compatible without having to resleeve.
One thing I am set on is the turbo
IHI RHF5
Old Jan 3, 2008 | 10:54 AM
98vtec's Avatar
moderator emeritus
Default Re: (Pilotx1)
currently the only two pistons that are known to work with FRM are Mahle and JUN pistons....and i wouldnt put high compression JUN pistons in a turbo motor.....
sleeve it and get it over with. If you are building an engine for a friend, you dont want to be a guinea pig and it blow up and ruin whatever reputation that you have.
Old Jan 4, 2008 | 01:02 PM
Pilotx1's Avatar
Default Re: (98vtec)
do you know if i can get away with the mahle h22 pistons in my h23, specifically will the compression be low enough to make it worth running the turbo?
Old Mar 4, 2008 | 07:58 AM
MJOLNIRvTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by badassCRX &raquo;</TD></TR><TR><TD CLASS="quote">I am in the process of building this H23 for a friend. So far the mods are:
eagle rods
king berings
arp head studs
stock valve train
mitu T25 turbo
stock crank
thanks</TD></TR></TABLE>
ewwwwww t25.... lol peak boost at lke 1500 rpm..goodluck with that one. might as well sell it to some highschool punk, and buy yourself a garret 35r
Old Mar 4, 2008 | 08:17 AM
98vtec's Avatar
moderator emeritus
Default Re: H23 build (MJOLNIRvTEC)
and you felt the need to bump a 3 month old thread to say that?
Projectludatic
Oct 7, 2010 10:38 PM
GraphiteMW
May 1, 2007 05:54 PM
crazykid
Jul 25, 2006 04:55 AM
92hondalude
Nov 5, 2004 02:54 PM
btleier
Aug 4, 2003 01:58 PM
