Engine Chip
Old Dec 29, 2007 | 12:55 AM
Immortal-Prelude's Avatar
Default Engine Chip
Something I have always wondered about chips for ECU's and ****
I know it's for vtec timing, however I don't drive a vtec car; h23, what does a chip even do and where could i get one and would it work for an h23
My friend chipped his e30 bmw and it helped him quite a bit, a huge pull from before
Let me learn some more please
Old Dec 29, 2007 | 12:59 AM
98vtec's Avatar
moderator emeritus
Default Re: Engine Chip (Immortal-Prelude)
chips are garbage.
a real CHIPPED ecu's sole purpose is to place a basemap which was created by a tuner, in order for you to safely get to your nearest tuner so they can make the map TUNED for your engine. Do not get a chipped ecu unless you plan on someone physically connecting their laptop to your car and making changes in real time or on a dyno.
these chips you see on ebay are garbage. chipped ecu's are NOT tunes. They are at best a guess which will make the engine run decent.
Old Dec 29, 2007 | 11:44 AM
Hawkze_2.3's Avatar
No, it's not just for VTEC timing. All a chip is capable of doing is adjusting timing and air/fuel maps for the most part.
Anything you find for a Honda ir probably garbage like 98vtec just said.
Has you friend dynoed his BMW? You can say you felt a 'huge pull' but it can very easily be in your head.
Old Dec 29, 2007 | 11:48 AM
Default Re: Engine Chip (Hawkze_2.3)
I mean because i've raced him before he had his chip and it was pretty bad and after he got the chip he could keep up better He spent quite a bit on it however, i think it got it from bavarianmotorspots.com
Old Dec 29, 2007 | 11:52 AM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Immortal-Prelude &raquo;</TD></TR><TR><TD CLASS="quote">I mean because i've raced him before he had his chip and it was pretty bad and after he got the chip he could keep up better He spent quite a bit on it however, i think it got it from bavarianmotorspots.com </TD></TR></TABLE>
Ok, yeah that's probably a 'good' chip then. No one really makes stuff like that for Hondas, we can get things like Hondata, Crome, Neptune, etc to let us modify the ECU on our own. It lets you adjust everything yourself so it's a lot better than a chip someone else made with a static program.
I know that BMW crap is $$$$$$$$$$$, my dad just paid $500 for a little trunk lid spoiler for his '04 5-series
Old Dec 29, 2007 | 12:04 PM
That's what i was thinking, would it do anything for me to get a program like Crome for a na car non vtec?
Old Dec 29, 2007 | 02:10 PM
borat's Avatar
Not unless you have a lot of modifications would a retuned ECU gain you very much. You could advance the spark and lean the fuel a bit, maybe get 3 or 4 more horses out of a stock motor, but at the expense of reliability. I would say you need I/H/E at a minimum before you should consider getting tuned.
Ej1Stolo
Aug 19, 2010 08:21 AM
gofastmobile
Mar 17, 2007 08:27 AM
darockstar
Mar 28, 2006 02:52 PM
ludaboy93
Feb 24, 2005 07:10 PM
80884
Sep 27, 2003 02:36 AM
