Help!!!
Old Aug 12, 2016 | 08:09 PM
Dustin Whinnery's Avatar
Default Help!!!
I have a 1994 prelude with a swapped f22b2 and im trying to replace the crank pulley and the woodruff key isnt going in all the way any suggestions? Would be appreciated
Old Aug 12, 2016 | 08:17 PM
slomofo's Avatar
GDD Member
Default Re: Help!!!
Sorry, not trying to sound like a dick, but you have the crank pulley off when trying to put the key in, right?
And you have the key positioned correctly, right?
Correct key, right? (Some are flat, some have a half moon on one side).
Old Aug 12, 2016 | 08:39 PM
Default Re: Help!!!
No the pulley is on there when trying, and the key has kind of a notched angle i really dont know what way its supposed to go on when i got to help out the key was off
Old Aug 13, 2016 | 07:02 AM
slomofo's Avatar
GDD Member
Default Re: Help!!!
Dude, you need to take the pulley all the way off, then you'll be able to see how the key goes in.
Old Aug 13, 2016 | 07:59 AM
Default Re: Help!!!
Ok will do thanks!
Old May 15, 2018 | 07:19 PM
Throttle2009's Avatar
Default Re: Help!!!
I cannot seem to get the key back into the slot fully. It seems that something is out of alignment and I cannot get the key back in. Any idea what I can try?
Old May 17, 2018 | 09:03 PM
motoxxxman's Avatar
Default Re: Help!!!
is the key rectangular or semi-circle?
If the key is rectangular, and appears to have a "notch" or something, that means the key is damaged, and you should just buy a new key. Check the slot in the crank and the crank pulley for damage too.
Also, if the key is semi-circle, you need to install it with the pulley off. If the key is rectangular, you can install it with the pulley on or off.
Shownutz
Oct 15, 2014 11:19 PM
:::SIRll_EJ1:::
Sep 25, 2008 10:55 AM
EG6 Love
Mar 14, 2008 07:54 PM
DC4 Rasta
Aug 27, 2007 12:50 PM
EG_Civic_Si
Mar 1, 2006 06:14 PM
