Igintion lock cylinder
Old 07-22-2017, 03:07 PM
Eric Brooks's Avatar
Default Igintion lock cylinder
I have a 92 prelude and I'm trying to replace the old ignition lock cylinder and I can't figure out how to remove the old one
Old 07-22-2017, 04:33 PM
holmesnmanny's Avatar
Default Re: Igintion lock cylinder
there is a screw you need to remove that locks it into place, then you need to have the key in a certain position, normally the 1 position, but you can check the new lock cylinder and you will see where it needs to be, then you need to push in the pin that's in the hole in the steering housing that pushes in the pin in the lock cylinder and then just pull out the lock cylinder
Old 07-22-2017, 04:36 PM
How do I remove that screw if its the one I think it is it looks like I have to remove the steering shell to get to,it
Old 07-22-2017, 08:44 PM
https://youtu.be/TasbM4SPxh0
skwigelf
09-30-2015 08:23 AM
Shaw14
06-25-2010 06:58 PM
Kipper-Fish
11-27-2008 09:17 AM
bsclywilly
Audio / Security / Video
06-02-2007 08:33 AM
Quick Reply: Igintion lock cylinder
