Rear Ball Joints
Rear Ball Joints
I've recently acquired a 4th gen to turn into my next Lemons/Chump racer. I want to replace all the suspension wear items- the front parts and pieces are pretty easy to source, the rear not so much. I plan on doing poly bushings through out, but I'm having a hard time with the ball joints (one in particular). Excuse my verbiage if I'm not calling the pieces by their proper names. The upper-arm ball joint appears to be able to be replaced by the same one as the front upper, so that's fine. The rear toe control arm, as I found in another thread, can be replaced by the complete arm from a 5th gen- fine. The real question I have is what about the ball joint in the knuckle? Is there a known replacement for it? I could just re-boot it if I had to, as there's no noticeable movement in it (the boot is dry rotten) but I would prefer to replace it.
Re: Rear Ball Joints
Im saying that I found ones for my 5th gen from our local parts store.
Your job to find out does 5th gen parts fit 4th gen and where to get em
yes i have em on my 4th gen
http://www.rockauto.com/en/catalog/h...trol+arm,10401
i used the DORMAN ones there 45$ ea plus shipping
wstef
03-07-2004 11:58 PM
