97 Honda Prelude, starts but won't crank.
I have a 97 Honda Prelude, recommended rebuild to spec, brands new battery, starter, alternator, fuel pump all was missing. Main relay and fuses are fine, good fuel pressure and working injectors, cylinder pressure is within spec. Timing was supposedly set correctly and distributor. I'm getting fuel all the way up until the fuel rail but once I get to the injectors they don't spray out I have pulse on the injectors so at this point I'm lost. What can it be?
db2b17a-R
07-21-2002 06:14 PM
