External ATTS cooler
Old Aug 31, 2017 | 06:34 PM
tsamadhana's Avatar
Default External ATTS cooler
99 Honda Prelude SH
Does it matter which 2 lines from ATTS connect to External Cooler Unit?
I am instaling a Mishimoto Radiator and Mishimoto MMTC-U Oil cooler.
Old Sep 1, 2017 | 08:14 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: External ATTS cooler
The two lines are not directional... you can connect them either way. Just make sure that the new oil cooler is directly in a space that is visible through the bumper cover so that it receives direct air flow.
Old Sep 2, 2017 | 09:03 AM
tsamadhana's Avatar
Greatly appreciated for your answer, been looking every where for it, Thank you.
Does this cooler has to be the same height with the ATTS unit or it is ok to mount it higher than the ATTS unit itself, will ATTS strong enough to pump the ATF up to the cooler?
Old Sep 2, 2017 | 09:07 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Try not to go too much higher... I would try to keep it as low as possible so as not to over work the pump.
Old Sep 3, 2017 | 09:00 AM
tsamadhana's Avatar
Will try, thanks again.
Old Sep 12, 2017 | 03:53 PM
tsamadhana's Avatar
I finished installing Mishimoto Radiator and separate Mishimota ATF Cooler for ATTS.
I drained and refilled ATTS and it took appx..8qt for the fluid to come out thru the Level Hole.
I disconnected the Right (Pass. side) ATTS hose on top of the Transmission right before Metal Tubing and put little funnel onto the rubber hose. It much easier than filling using Fill Hole above the Level Hole.
My question is do I need more Fluid since I have External Cooler? I think the External Cooler itself and those In and Out Hoses will hold about 1qt or more ATF.
Old Sep 13, 2017 | 05:56 AM
snobordboy's Avatar
Moderator
Best way to check is to lightly operate the vehicle enough to move fluid through the whole system again, and then let it settle and recheck the level. How much more would obviously depend on the size of cooler and length of lines. If you had filled them as a test before install, you would have a more exact figure.
89lowlude
Jan 6, 2013 04:12 PM
austrian type-R
Sep 27, 2007 05:28 AM
austrian type-R
Sep 5, 2007 12:58 PM
HOTSHOT-H22A
Jul 11, 2005 03:23 PM
Avante
Jul 10, 2002 04:14 AM
