Tranny Shop Couldn't Fix 5th Gear Grind
Old 08-31-2009, 02:53 PM
Ralleh's Avatar
Default Tranny Shop Couldn't Fix 5th Gear Grind
Clutch went out out of town and I had my 97 base towed to a local transmission shop and the guy said fixing the grind would be no problem. 1300 bucks later and it still grinds at pretty low rpms going into 5th. I took it back, the guy had it for 5 weeks before I got it back again and it was fine for a few days and then grinding again. Replaced (or said he replaced) everything to do with the 5th gear, including the shift fork, but it's still grinding as it did before the clutch went out.
At this point I called the CC company and am disputing half of the charge, but I want to know if there is some kinda honda voodoo that is required to fix this or if the guy just lied about what he did. I mean, this is a transmission only shop and every time I've been there I have seen hondas, but I have no idea.
Any ideas are appreciated.
Old 08-31-2009, 03:01 PM
autoluder's Avatar
Default Re: Tranny Shop Couldn't Fix 5th Gear Grind
http://members.shaw.ca/FifthGenTSB1/...ar%20Grind.pdf
Old 08-31-2009, 03:03 PM
autoluder's Avatar
Did you replace 5th gear, the fifth gear sleeve set and the fifth gear shift fork, using honda parts?
Old 08-31-2009, 03:05 PM
Ralleh's Avatar
All of those parts are listed on the invoice as having been replaced. I even gave the guy that Honda bulletin.
Old 08-31-2009, 05:53 PM
Kronn 98SH's Avatar
For as much as you've spent, you could have purchased a completely different transmission.
Old 09-01-2009, 06:44 AM
dans4's Avatar
I replaced my clutch with an Exedy OEM clutch and never grinded 5th since. On stock clutch i would grind every time i skipped gears to go directly to 5th.
Old 09-02-2009, 10:14 AM
Ralleh's Avatar
Double-clutching seems to stop the grind, does that mean anything?
Old 09-02-2009, 10:17 AM
ArmaanOG's Avatar
get some good tranny oil, when my 3rd and 5th used to grind on my h23 lude. i used 2 quarts of ROYAL PURPLE MOTOR OIL (NOT TRANNY OIL; MOTOR OIL) Stopped all of my grinds i was so happy! also heard redline does miracles with trannys
Old 09-02-2009, 10:46 AM
Ralleh's Avatar
Guy said he put in RP's synchromax this last time around.
Old 09-02-2009, 11:09 AM
vinuneuro's Avatar
Yea it means it's a syncro related problem. Send me a pm. I can direct you to someone who can help you with this.
Old 09-02-2009, 01:14 PM
lude98SH's Avatar
Supposedly running a synthetic oil in a manual trans may cause problems with slipping.
Old 09-02-2009, 01:15 PM
vinuneuro's Avatar
No.
Old 09-02-2009, 03:05 PM
Ralleh's Avatar
I'm prolly gonna double-clutch from here on out and try not to think about it. Hopefully the cc company can twist the guy's arm into crediting me for the part he F'ed up. I don't think I wanna go through this again, I was just wondering if there is some reason why the synchros in a prelude are that much different from what a guy who has worked on hundreds of transmissions has seen. Just seems kinda weird.
Old 09-02-2009, 04:49 PM
dagle's Avatar
notorious 5th gear grind, motor oil will work but I still suggest the Honda MTF over it. I ran mobil1 10w30 in the tranny (as per the manual) since I had it around but thats not as good as the MTFs out there. not worth double clutching a daily driver all day imo.
d16efsedan
16
11-29-2016 09:35 PM
gabe768
06-07-2010 03:06 PM
Ralleh
07-09-2009 03:51 PM
94jdmlude
12-30-2008 02:38 PM
Luchini
01-13-2004 12:32 AM
Quick Reply: Tranny Shop Couldn't Fix 5th Gear Grind
