h22a4 in ek..cel code 8. help
Old Aug 19, 2009 | 01:41 PM
juan400hp's Avatar
Default h22a4 in ek..cel code 8. help
I HAVE AN H22 IN MY EK ...is has the check engine light on code 8..= top dead center sensor...I was told that sensor is in the dizzy, I have an obd1 dizzy.. so I swaped it with a working dizzy out of my boys running h22ek and the code is still on...and it still starts up the same.( a few cranks b4 turns over)......what can it be?? If the motor is off timing from the timing belt, would it cause the sensor on dizzy to misread???
P.s....I had my head removed after cause very loud rockn/knocking noise from head and machine shop said all 8 exhaust valves were bent and 1 valve guide was broken...can it be that it jumped timing some how even tho the timimng mark on the cams were dead even? And that's wat caused the code? Cause the car was fine till 1 day out of the blue after I installed the p28 back in and started it....(I take it off every night). THANKS FOR UR HELP...
Old Aug 19, 2009 | 03:05 PM
Enzo15's Avatar
Default Re: h22a4 in ek..cel code 8. help
Im no expert, but if you put in a working dizzy, but didnt clear the code, I believe the code will still show up, even if its working the way it should.
Old Aug 19, 2009 | 03:09 PM
juan400hp's Avatar
Any help is appreciated....
Old Aug 19, 2009 | 03:12 PM
juan400hp's Avatar
I disconnected the battery for 5 minutes...don't that clear it? and but y would the car start up the same way as with the bad 1?..well thanks enzo....every little help counts
Old Aug 20, 2009 | 08:11 PM
juan400hp's Avatar
Help x2
hondachris1994
May 21, 2015 09:55 PM
Syke909
Apr 3, 2013 01:31 PM
ahc'monracing
Oct 8, 2002 04:43 AM
