what is this plug?
Old Aug 29, 2009 | 06:51 PM
AznBlueBoy's Avatar
Default what is this plug?
its located on the passenger side in front of the intake if you had a short ram. its mounted against the inside of the fender. some black wires coming from the bottom of it going to the rad, horns maybe? not too sure.
Old Aug 29, 2009 | 06:53 PM
bakertime's Avatar
Default Re: what is this plug?
A picture would be really helpful.
Old Aug 29, 2009 | 06:56 PM
97BB6Type-SH's Avatar
if u can not post a picture please follow the wires and tell us where they go to.
Old Aug 29, 2009 | 08:13 PM
runbycommies's Avatar
its for the intake control diaphram the plug plugs into the intake control solenoid valve
http://www.phonecallsfromthedead.net.../h22swap2.html
Old Aug 29, 2009 | 08:26 PM
AznBlueBoy's Avatar
alright here is a pic.
http://s858.photobucket.com/albums/a...t=IMG_0561.jpg
Old Aug 29, 2009 | 08:41 PM
mafia's Avatar
Are You talking about that ground?
Old Aug 29, 2009 | 09:02 PM
AznBlueBoy's Avatar
the thing that is bolted down with a green wire coming from it. has some black wires coming from the bottom of it.
Old Aug 30, 2009 | 05:05 PM
bakertime's Avatar
Looks like a relay to me...the ground is unrelated, it just happened to be used as a grounding point.
Old Aug 30, 2009 | 07:28 PM
AznBlueBoy's Avatar
relay for? lights? i have a problem with the headlights on my car. It was loose so i just tightened it. Hopefully that solves the problem.
Old Aug 30, 2009 | 07:32 PM
TheJGB3's Avatar
That looks like HID ballast wiring. I had originally thought the OP was wondering about the resonator chamber for the stock intake because there is a vacuum tube for the butterfly in it.
Old Aug 30, 2009 | 07:53 PM
AznBlueBoy's Avatar
not talking about the hid ballast wiring. im talking about the white thing thats bolted to the inside of the fender.
Old Aug 31, 2009 | 03:34 AM
preludestud11's Avatar
Yes that is a relay/ground for the headlight.
JPerkMr954
Jun 19, 2012 08:30 AM
Dontoh
Jul 26, 2011 04:50 PM
exile29
Oct 6, 2006 08:53 PM
jpnucrx
Jun 17, 2006 09:44 AM
meagainsttheworld
Apr 14, 2006 06:20 AM
