Question About the difference in Code 1 and 41
Old Sep 12, 2009 | 03:34 PM
The AW Alchemist's Avatar
Default Question About the difference in Code 1 and 41
First Id like to state that I installed an AEM Wideband on my H22. It works cool.
But I ran into one issue with it. It would throw itself into open loop on code 41, and had the engine running like crud.
Now I Fixed that issue with a 1k watt resistor.
I plugged A6 into A25 and linked the to with a 1k watt resistor. Worked fine, and no more code 41.
I did take it out and give it a good test out to see what would happen up and down the block. I did run into a different issue that has me wondering.
I didn't check the resistor to see if I blew it out, I did hear a pop, so Im assuming that I blew a fuse or the resistor out. Either or, Im still wondering about this.
What is the difference in the code 1 and code 41? Code 1 refers to the level of oxygen content in engine, and code 41 is O2 sensor, and throws the engine into open loop mode, which I don't want.
Does code 1 throw the engine into open loop as well? Or does it perform something else.
Old Sep 13, 2009 | 06:02 PM
Default Re: Question About the difference in Code 1 and 41
No one
Old Sep 14, 2009 | 11:35 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Any emission related DTC will put you into open loop. So yes, code 1 will.
LJS
Oct 3, 2017 01:14 PM
blwn95civic
Sep 19, 2007 11:30 AM
whagkangmakulet
Nov 25, 2002 12:27 PM
wuhungsixxx
Jul 15, 2002 03:45 PM
