CV Shaft Problem?
Old Aug 19, 2009 | 06:33 AM
integ_lude's Avatar
Default CV Shaft Problem?
Good morning,
I have a 98 Honda Prelude Base. I had a CV shaft that was leaking so instead of replacing the boot I replaced the entire shaft. The shaft I got was from Advanced Auto and it seems that its to small in length. The first time I put one on it stretched the boot so greese came out (I had the car jacked up). I brought that one back and got another and jacked up my car, put in the CV shaft and the boot stayed in place on the inner.
But now when I drive I hear a cracking noise when I start out, it goes away when I am moving. When I steer it seems to be louder.
I jacked up my car and greese seems to be coming out of the boots and the shaft just seems a tad to short. I made sure I had the correct one before I left its for my driver side.
Any thoughts? This is the third CV shaft and I have checked everything, this is not the first CV shaft I have put in I have done 4-5 cars before.
In replacing this is what I did:
1. Remove tire
2. Lower ball joint
3. Tie Rod
4. Upper ball joint
5. Brake line bolts (3)
6. CV shaft bolt
7. Removed CV shaft
Installing I put the CV shaft in, hammered the front so it would fit snug, and followed the steps above in reverse order. Did I miss something?
Thx
Old Aug 19, 2009 | 10:02 AM
LUDEaKriS's Avatar
Default Re: CV Shaft Problem?
I am having that same problem but both my axles do that and my f'n tranny is stuck in 1st gear and there is loose metal in there.
Old Aug 19, 2009 | 12:06 PM
integ_lude's Avatar
Does anyone have the measurements of a stock CV Driverside length tip to tip?
Old Aug 19, 2009 | 05:04 PM
TheJGB3's Avatar
This is exactly the reason why when my boots go I am REBUILDING my OEM half-shafts myself. The cost is about the same, and I will have HONDA CV boots, instead of schwag ones. The only bad thing is no lifetime warranty like the parts store ones. My OEM boots and joints are TEN YEARS old, have 137,000 miles on them, and show no sign of the rubber drying out/cracking anytime soon, so I am not worried.
Old Aug 19, 2009 | 07:49 PM
preludehotr's Avatar
New User
im hoping to do this tomorrow i hope it all goes well for you!
Old Aug 19, 2009 | 09:33 PM
TheJGB3's Avatar
I ALWAYS compare the old part to the new one to make sure they match EXACTLY before proceeding to install the new part. Have you already returned your core? If not, you can measure it.
Old Aug 20, 2009 | 09:47 AM
integra15's Avatar
This is the reason I never buy anything but rebuilt Honda axles. You dont have to worry about them being unbalanced or the wrong size. FYI, the exact lengths are in the shop manual.
Old Aug 20, 2009 | 01:33 PM
SKDRCR's Avatar
I haven't had too many problems with the carquest axles in honda's.
When I install them I don't hammer them in, I leave the lower ball joint
disconnected and push the spindle forward towards the transmissoin until
the axle is in there snug. It should go in fairly easily.
B_Swapped93
Oct 28, 2013 01:38 AM
MadVladCivic
Jan 22, 2013 12:02 PM
darot
Transmission & Drivetrain
Jul 18, 2009 08:22 AM
GruvyTune
Jul 22, 2002 12:34 PM
