Zero Clearance
Old Aug 25, 2009 | 08:10 AM
Outlaw-Hondaz's Avatar
Default Zero Clearance
I got the h22a4 motor...wont start....they say it might be cuz of zero clearance??...what is the zero clearance?
Old Aug 25, 2009 | 08:12 AM
Szandor1966's Avatar
Default Re: Zero Clearance
what is the motor doing
Old Aug 25, 2009 | 08:54 AM
pentaq's Avatar
It means your engine is seized and stuck. Happens when the crankshaft bearings fail.
Old Aug 25, 2009 | 05:10 PM
the motor cranks but wont start fully...its not the starter for sure and sounds like it could be the timing belt...but mechanics are sayin its zero clearance???
Old Aug 25, 2009 | 05:20 PM
street_ride14's Avatar
hit the mechanic in the ***** .. that should show him zero clearance.
No seriously though, double check that the timing is set right at crank and camshafts. Also check to see if distributor shaft is in correctly as it has two ways to go in and could cause early or late firing sequences.
Old Aug 25, 2009 | 05:57 PM
The AW Alchemist's Avatar
Do you know why mechanics say **** like that? They say it to see if you know anything about cars. If you just agree with what they say, than your pretty much ****ed!
Old Aug 25, 2009 | 06:41 PM
Targa250R's Avatar
be professional
What he means by "zero clearance" is what most people refer to as an "interference" type engine, where the pistons will hit and bend the valves if the timing belt breaks.
If the engine cranks but will not start, troubleshoot procedure is as follows:
1. When turning the key to position II (ON), make sure the Check Engine light comes on and then goes out after two seconds. If the light stays on, check the main relay, ECM fuse, and ECM.
2. If the check engine light goes out after two seconds, you should next remove the oil cap and look inside the valve cover while someone cranks the engine for you. If the rocker arms/cam followers are moving, the timing belt is intact. If the rocker arms are not moving, the timing belt is broken.
3. If the timing belt is intact, check for spark at the plugs. Pull a spark plug and reinsert it into the wire. While you hold the ground electrode against a bit of bare metal in the engine bay (valve cover nuts work fine), have someone crank the engine while you look for a fat blue spark. Don't get zapped, it will hurt. If you have weak yellow spark or no spark, check for a problem with the ignitor (more likely with external coil distributor) or ignition coil (more likely with internal coil distributor). Make sure you actually pull a plug and look at the electrodes to make sure they aren't worn down to nothing, expecially when using copper plugs. Also check the contact points on the distributor cap and rotor and replace if worn or corroded. If your spark plug wires are cheap and/or falling apart, replace them.
4. If you have spark, check for fuel. If the plugs were wet and smelled of gasoline when you pulled them in the previous step, you have fuel.
5. Run a compression test in all cylinders. You will need a compression meter.
6. Check cam timing.
Old Aug 25, 2009 | 07:34 PM
Thanks for all helpful inputs
Old Aug 26, 2009 | 08:07 AM
bluedlude's Avatar
it would help to have a little background to help you with the problem. is this a new motor? did this just all the sudden happen after having no problems?..........
Old Aug 26, 2009 | 12:21 PM
motor has 104xxx miles....and yes happen out of the blue
Roryz
Aug 1, 2014 01:04 AM
DroppedTegra
Oct 21, 2011 08:28 AM
ganjasnack
Mar 29, 2009 07:26 AM
HSPxCARDO
Oct 23, 2007 10:10 AM
LoudLX
Nov 8, 2004 03:54 PM
