Axle Question
I need to replace the left side axle in my 93 prelude but my problem is that the swap is an SH. What axle do i replace it with since the half shaft won't bolt up to the block? Has anyone made an adapter plate yet? The one that i have on there has a welded piece of metal but that broke and I don't have a welder.
Why Why Why would you have a SH engine and trans in a 4 gen? But if you need to keep it . I think if you measure the axle to make sure it is the right length then take apart the inner cv and replace it with a SH inner cv. If you need SH axles I have a set for cheap. But I would double check that is all you need.
