serious compresson problem help
Old Sep 12, 2009 | 09:26 PM
clean ass lude's Avatar
New User
Default serious compresson problem help
OK 98 prelude cylinder one 60 cylinder two 168 cylinder three 170 cylinder four 50 now my question is the camshafts have some flat spots in them could that cause this compresson difference problem? or would I be wasting my time replacing the camshafts?
Old Sep 13, 2009 | 04:59 AM
82Lude Man's Avatar
Default Re: serious compresson problem help
Sure it could contribute to the problem but you have other issues also. Have you adjusted the valves recently? If not then a bad cam would be easy to spot by checking the valve lash. If you have adjusted them recently then you may have miss adjusted them.
Was this a dry test? If so did you do a wet test? A wet test can help rule out rings as the cause.
You could also have burnt or bent valves, especially if you recently adjusted the valve train and you did it wrong..
Old Sep 13, 2009 | 07:21 AM
New User
it was a dry test and I never messed with the valves or adjusted anything am going to try a wet on
Old Sep 13, 2009 | 07:30 AM
street_ride14's Avatar
major causes for low compression == piston ring damage or bent valves.
digitaldelusion
Mar 24, 2009 11:32 AM
2000siturboR
Sep 20, 2007 02:00 PM
DOHC_EF
Jun 29, 2004 03:31 AM
allmotorls95
Apr 24, 2003 04:37 PM
96tegsr
Dec 30, 2001 02:41 AM
