Intake Manifold Plenum spacers
Old Sep 8, 2009 | 07:58 PM
ketchup's Avatar
Default Intake Manifold Plenum spacers
Took out my intake manifold this weekend to clean out the EGR and decided to take it all apart and clean it all up GOOOOD........then instead of using oem honda plenum gaskets (they call it a bypass valve gasket) I went and made my own. Made them from the same stuff Hondata used for their Heatshield IM gasket. I figured why not, it'll be a nice little set of heatsoak fighting gaskets - plus these will give me a little extra hp/tq.
So I was wondering what other engines can use H22 plenum spacers? F-Series?
Old Sep 8, 2009 | 08:47 PM
nus_dogg's Avatar
Default Re: Intake Manifold Plenum spacers
Oh nice! I need a set of that for my H. Remove my current IAB plates? and just slap on those?? and I guess they work as a IAB delete?
Old Sep 8, 2009 | 09:59 PM
ketchup's Avatar
Yes, for an IAB delete you can use one.
As for now I'm keeping my IAB funtional and just using them as a gasket with benefits.
Old Sep 8, 2009 | 10:28 PM
lude_lover's Avatar
how much would those cost?
Old Sep 9, 2009 | 03:59 AM
918sAccord's Avatar
x2 those look good
Old Sep 9, 2009 | 04:34 AM
nus_dogg's Avatar
Oh cool. The pics explains alot. So whats their purposes?
Old Sep 9, 2009 | 08:59 AM
Apex1972's Avatar
damn ,how did you make those. very nice.
Old Sep 9, 2009 | 01:00 PM
ketchup's Avatar
For me, I'm using them as gaskets but I get the additional benefits of increased air volume and heat soak resistance - keeps intake air temps colder.
You can use one as a IAB delete and you would probably still see gains.
Old Sep 9, 2009 | 01:27 PM
Apex1972's Avatar
how much do you typically gain when removing them? on a stock h22 IHE?
Old Sep 9, 2009 | 01:43 PM
ketchup's Avatar
I don't think anyone has dyno numbers of this but it is said that you will see gains from midrange to top end.
I'd love to dyno test it but it'll have to wait til after I get my car BAR'd.
Old Sep 10, 2009 | 08:05 AM
ketchup's Avatar
So will these only work for the H22 and H23 intake manifolds?
Old Sep 10, 2009 | 12:14 PM
95greenlude's Avatar
^and GSR.
But great dIY
Old Sep 10, 2009 | 02:49 PM
ketchup's Avatar
Originally Posted by 95greenlude
^and GSR.
But great dIY
What's the engine code for those GSR's?
Old Sep 10, 2009 | 03:00 PM
mikesrex's Avatar
most of the people I know usually stack a couple spacers (ported out of course) to increase plenum size. maybe this would be better to reduce temps?
and LOL at gaskets "with benefits"
Old Sep 10, 2009 | 03:19 PM
ketchup's Avatar
yea, I figured since I was going to install the hondata heatshield, might as well make some for the IAB and lower my IAT even more.
The other thing that I found interesting while I was searching on HT is that jdogg, 98vtec, and mgags7 (yea...that's right, I'm naming names!) all seem to agree that just removing the IAB completely yield decent gains across the powerband.
I may just have to test that out if no one steps up.
Old Sep 11, 2009 | 12:10 AM
B18C1 iirc
Old Sep 11, 2009 | 04:43 PM
92civlude's Avatar
haha you like that eh? I should use it as my motto.
Are you talking about removing the plate altogether and bolting the upper half directly to the lower half with shorter bolts?
Old Sep 11, 2009 | 06:21 PM
agrabowski@ymail.com's Avatar
how much would those gaskets cost and can you make a intake gasket for a h23 the one that goes between the head and intake manifold?
Old Sep 11, 2009 | 06:51 PM
Acidcrakker's Avatar
I made my own spacer with other IAB plates from other engines. Halloed them out, and smoothed the edges down. All I used was about 5 dollars worth of dremmel bits and a spare IAB spacer, and JBwelded the holes up.
Old Sep 11, 2009 | 08:21 PM
ketchup's Avatar
Yes.
That's was what most people have done but I don't have a welder and I wanted to use the stuff that would keep the IAT cooler.
Old May 7, 2010 | 12:49 PM
918sAccord's Avatar
still make these?
Old May 7, 2010 | 03:29 PM
jlude90's Avatar
Just an FYI this won't work as an IAB delete, the upper and lower plenum are designed differently, and will leak.
The part that is in the front center, around the bolt hole, the little square lookin thing with the bottom cut out, will leak. You can see it in the picture of the manifold, how the upper plenum shadows the IAB plate.
Old May 7, 2010 | 04:45 PM
92civlude's Avatar
The F22A6 has the same IAB plate as well.
Old May 8, 2010 | 06:14 AM
Kyleb1115's Avatar
I really think you should sell these! haha when i gut my butterfly plate, ill be interested! the manifold gasket and TB gasket too dude! where did you get the material to make it??
Old Jun 13, 2010 | 02:03 PM
ketchup's Avatar
Negative, they do not leak when used as an IAB delete. The bottom gasket is identical to the top gasket so the upper and lower plenums being different in design does not matter.
Thanks! I'll add that to the list. I'm in the process of making one for GSR's, as the b18 plenum gasket is different than that of the h22.
PM me to purchase.
