H22a Problems
Old Aug 19, 2009 | 08:01 AM
cometid's Avatar
Default H22a Problems
i recently picked up a 95 GSR Integra with a H22A swap (why i posted in prelude). The kid had it running in his prelude but since the swap it doesnt run right. It starts but sounds as if its not getting enought gas, loading up or possibly out of time, maybe bad injectors? Anyone have any suggestions on what this possibly could be? Thanks in advance, Greg
Old Aug 19, 2009 | 09:54 AM
LUDEaKriS's Avatar
Default Re: H22a Problems
I ran into something like that when I did my swap, I didnt have the resistor pack plugged in and it ended burnt up my ecu after a week or so of not running right. you could check the fuel pump filter, fuel filter, and if that doesnt work get your injectors checked out (if its a fuel problem) it could also just be a mishap while he was wiring and forgot something.
Old Aug 19, 2009 | 10:05 AM
street_ride14's Avatar
well you just named a few yourself, could be out of time, bad fuel injectors, dirty fuel, clogged fuel rail / filter / hose .. check timing first though.
Old Aug 19, 2009 | 07:07 PM
cometid's Avatar
Thats what i figured. His mechanic checked all the wiring and said everything check out good. I want to buy most of the basic stuff brand new so i know that its up to date, but with my busy schedule (college 8-2 and work 3-9 monday- saturday) i never have time to do anything. But i will check pretty much everything and when i get it up and going ill let you all know how it runs... Thanks Guys
Old Aug 20, 2009 | 01:41 PM
SKDRCR's Avatar
Which ecu are you using? The p28 isn't programmed to run with the 345cc
injectors of the h22a. What are you using to control the fuel?
Old Aug 20, 2009 | 07:34 PM
cometid's Avatar
im using the ecu out of the 94 lude...p13
Old Aug 21, 2009 | 04:04 AM
LUDEaKriS's Avatar
I'm running a chipped p28 with an s300 and 550cc rc injectors
Prelude 4 life
Feb 2, 2010 07:31 PM
mcbarto826
Oct 18, 2009 10:02 AM
louevilhatch
Jun 20, 2007 07:22 PM
koreachangsu
Sep 12, 2006 06:59 PM
asmallsol
Sep 4, 2006 05:55 PM
