this is a engine builders question
Old Sep 2, 2009 | 03:42 PM
lrayford's Avatar
Default this is a engine builders question
the only cranks iv been able to find for our h22 motors are 100mm stroke.. and stock is 90.. so with a 100mm stroke wouldnt that put the piston into the head with stock sized rods? or am i way off?
Old Sep 2, 2009 | 04:44 PM
dagle's Avatar
Default Re: this is a engine builders question
lol yeah it'd be 10mm taller... which is crazy.
what crank is 100mm? heres what I remember:
H22: 90.7mm
h23 : 95mm
F22 : 97mm
the rods should be different too shouldn't they ?
Old Sep 2, 2009 | 04:52 PM
crazes's Avatar
Moderator
H22: 90.7mm
h23 : 95mm
F22 : 97mm
thats the same thing i was thinking. cause unless you have a custom stroker crank its wat dagle said
Old Sep 2, 2009 | 08:44 PM
jlude90's Avatar
I think he means aftermarket, such as the BC kit
go with a honda crank, h23 crank plus type-s pistons is a nice, cheap, reliable combo
Old Sep 2, 2009 | 11:08 PM
ludetech's Avatar
actualy the f22 is 95 mm also its the f23 that has 97 mm but the crank journals are different size so yeah unless you want to use the f23 bottom end i would just get the h23 rotating assembly and put that in with the type s pistons
Old Sep 3, 2009 | 11:47 AM
jlude90's Avatar
F23 crank is 55mm mains, so you have to use the A4 block. The F22, H23 and H22a/a1 cranks are all 50mm mains and can be interchanged between
FYI
Old Sep 3, 2009 | 12:28 PM
ludetech's Avatar
thats why i said the journals are different size. and the h23 and h22 blocks are almost identical except for the the open deck on most h22s and the closed deck on h23s
Old Sep 3, 2009 | 01:06 PM
lrayford's Avatar
yeah the crank im talking about was a crower crank. i was just looking at prices just incase mine is messed up.. i think the bearings went and im trying to sell this motor either needing bearings for cheap of fixin it and selling it for a littel more.
what do u think if the motor was able to start by its self and run and idel by its self, but with a horriable (in my opion) knock and only was an audible knock for just over 2 miles.. but under 3 are the rods/ crank still striaght or what?
Old Sep 3, 2009 | 01:51 PM
Bangher4$'s Avatar
dont mean to thread jack but i have a question that you guys may be abl to answer.
h23 block/rods/crank with typ s pistons is a 12:1 ratio right? is that reliable?
can i use pump gas with that?
h23a1, does it have full float wrist pins?
Old Sep 3, 2009 | 01:55 PM
jlude90's Avatar
I was just clarifying your post And not all H22s were open deck, only the newer ones
and I'm running an H23 crank, H23 rods, and Type-S pistons, the only special machining was boring the little end on the rods for the full floating pins. Runs on pump gas and I daily drive it with stock headgasket and everything. I highly recommend this setup, I got the entire block, head, and all parts/machine work for right around a grand.
jdm.fanatic
Apr 24, 2010 04:29 PM
LudeyKrus
Mar 15, 2010 01:37 PM
95accordsir
May 22, 2008 10:07 AM
damntired42
Jan 29, 2004 08:55 PM
fastludeh22
Nov 20, 2003 09:08 AM
