switching core and cap to higher volt core
Old Sep 8, 2009 | 10:11 AM
turboorsupercharger's Avatar
Icon2 switching core and cap to higher volt core
hey guys, i got my 97 prelude and i want to put on a high volt core (the one im looking at puts out 46,000 volts). how much of a difference would that make in the car? o and its a stock h22 with just an full exhaust and intake.
Old Sep 8, 2009 | 10:38 AM
Default Re: switching core and cap to higher volt core
bump
Old Sep 8, 2009 | 07:28 PM
TheJGB3's Avatar
Do you mean a high voltage COIL? If so, nope it won't do a damn thing for you.
Old Sep 8, 2009 | 07:55 PM
Targa250R's Avatar
be professional
I have no idea what a "high volt core" is. I'm assuming that you're referring to the ignition coil.
Why do want to do this? Because some sucker marketing told you to?
Absolutely no difference.
The stock ignition system is good to 400hp+ and is composed of top quality components already. Leave it alone.
Old Sep 9, 2009 | 04:19 PM
82Lude Man's Avatar
If you are replacing a defective coil then sure why not but there should be no need for a higher output coil on an engine without mechanical issues.
Old Sep 9, 2009 | 05:07 PM
The AW Alchemist's Avatar
Yardly Pa, I think Ive seen you around before
Old Sep 21, 2009 | 06:05 AM
hey sry guy ive been off line for a while and yes i ment a hight voltage...sry i wasnt paying attention when i typed it... and thanks guys i wasnt really sure if it would even do anything my stock coil housing is crack and i was gonna just replace it and was thinking of just putting a higher voltage coil on.
Old Sep 21, 2009 | 06:07 AM
what do you drive i probably have seen you around as well since morrisville is right down the road from me
rick22snail
Jan 8, 2013 09:34 AM
NA_H22_Ej8
20
Feb 14, 2006 05:59 PM
ebp 99 si
Feb 11, 2006 10:20 AM
BB6-213
Aug 17, 2005 05:05 PM
Quade
Aug 19, 2004 04:55 AM
