ARP TORQUE
Old Aug 21, 2009 | 07:51 PM
LobeSex's Avatar
Default ARP TORQUE
ok i have an h23a1 and i rebiult the motor well im possibly gona have to take the head off i need the torque specs for the head studs but i lost the paper from arp, anybody know or know where i can find the torque specs on them?
Old Aug 22, 2009 | 07:56 AM
oranginal's Avatar
Default Re: ARP TORQUE
not sure about the h23 but just as a comparison on an h22 it's 80lbs with the ARP Moly Lube and 120lbs with Oil as the Lubricant. So be sure to use the correct spec for the lubricant type you use.
You can always give ARP a call, they are very knowledgeable and then you'll get an answer straight from the source.
Old Aug 22, 2009 | 03:17 PM
LobeSex's Avatar
sounds right...thanx alot
Old Aug 22, 2009 | 03:38 PM
dagle's Avatar
remember to seat the studs, clean out the threads, 3step torque sequence, and to do that multiple times and back them off before actually torqueing it on.
purestreetracer
Jan 11, 2010 10:13 PM
slo_b18
Jan 30, 2008 08:47 AM
truteg801
Jan 3, 2007 08:31 PM
one pnt 6 hatch
Apr 25, 2005 08:48 PM
