heated 02 sensor
Old Apr 2, 2011 | 07:19 PM
sil80's Avatar
Default heated 02 sensor
what would cause this to happen a heated 02 sensor
Old Apr 3, 2011 | 06:30 AM
Hawkze_2.3's Avatar
Default Re: heated 02 sensor
WTF?
O2 sensors are heated, they are made that way. They need to be hot to work properly.
Old Apr 4, 2011 | 05:39 AM
1GPlusSH's Avatar
Originally Posted by Hawkze_2.3
WTF?
x2...LOL
Old Apr 4, 2011 | 08:43 AM
sil80's Avatar
its throwing a code for an overheated 02 sensor most likely just wore out and went bad just wanted to ask
Old Apr 5, 2011 | 12:12 AM
HdeucedeuceA's Avatar
this
Old Apr 5, 2011 | 09:57 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
The heaters can and do over heat and many times will take out a PCM. replace it or unplug it.
Old Apr 5, 2011 | 02:15 PM
sil80's Avatar
I got it on the way my car is running so rich and spewing fumes out the exhaust which I am pretty sure is the o2 sensor causing it
Old Apr 5, 2011 | 10:57 PM
gstrudler's Avatar
Is it throwing a code for the o2 sensor? If the car has a lot of mileage, chances are the sensor is bad. You can replace it yourself for under $100. There is also the off chance you have an exhaust leak, which will also throw an o2 code, but probably won't make your car run as rich as a bad o2.
Old Apr 6, 2011 | 02:22 AM
sil80's Avatar
yeah its throwing a code for o2 sensor got one on the way and am pretty sure there is an exhaust leak too I just got the car and I got a headach driving it home because of the fumes
randomracing
Dec 26, 2008 08:37 AM
kev92ex4door
Jul 26, 2008 08:30 PM
amej8
Jul 11, 2006 06:25 PM
draxxus07
Oct 13, 2005 05:41 PM
CereaLand
Jun 30, 2004 12:01 PM
