H22a Engine harness
Old Apr 12, 2011 | 10:03 PM
mike541's Avatar
Default H22a Engine harness
Hey guys, just finished my build now I need to know where the best place to get a LHD harness at? I have a really nice JDM RHD harness but I know a lot of the wires have to be lengthened to fit. What's my best option? Use a H23 harness and add the 3 wires?(cheap route) Or buy H22 harness for left hand drive? Maybe someone out there has either H23 or H22 harness for sale.
Old Apr 13, 2011 | 04:52 AM
minilogoguy18's Avatar
Default Re: H22a Engine harness
If I had my engine out I'd make my own harness using the RHD one so that I could do a full wire tuck. H22 harness's are kinda hard to find used and usually expensive. H23a1 harness's can usually be found for like around $60 and adding the 1 plug for the VTEC oil pressure switch is easy, you should have the plug for the spool valve by your passenger side shock tower, just gotta lengthen it. Unless you have the S model in which you need to add knock and both VTEC plugs.
Old Apr 13, 2011 | 01:40 PM
mike541's Avatar
Ya i can't even find one on the web for sale... maybe I'm not looking hard enough. I'd like to buy an H23a1 harness and just add the wires. That's what I've always done. Alot easier than lengthening all of the wires on my JDM harness.
FunnyVictor86
Dec 28, 2008 04:15 PM
3.point.2
Aug 11, 2004 06:05 PM
3.point.2
Aug 7, 2004 03:29 PM
mstsh80
Jul 1, 2003 12:49 PM
