help w/vtec
Old May 17, 2011 | 03:35 PM
bain3277's Avatar
Default help w/vtec
1 have a 1992 prelude w/h22 w/p28 its a race car circle track what is the bare bones needed to run vtec.... i dont have speedo cluster..
Old May 18, 2011 | 05:21 AM
serrilion's Avatar
Default Re: help w/vtec
no need for a speed cluster due to the ecu reads engine load, speed ect.... depending on what prelude model you have you will just need to run the Oil presure switch wire to D6 on your ecu, should be a single wire... then Run VTEC + to A6 and then you need a ground. I've used B2 or A26 i beleive for the ground... here is a link...
http://www.dodo-upgrades.nl/pinoutp06p28p30.htm
You looking for VTS, VTM, and LG1 or 2
Old Jun 5, 2011 | 05:16 PM
bain3277's Avatar
worked great i did the oil pressure by pass and the vtec would only work for two laps them quit ??again and again
tofastgsr
Engine Management and Tuning
Oct 26, 2012 06:11 AM
kaoss_11
Apr 14, 2007 07:18 AM
AdamITR
Apr 17, 2003 03:00 PM
AdamITR
Apr 14, 2003 04:38 PM
