Piston Rod
Old Apr 14, 2011 | 10:27 PM
slvrcvc_9139's Avatar
Default Piston Rod
I need an h22a piston rod and i was wondering if the h22a1 piston rod was different?
I believe is a 93-96 h22a.
any other h22 has same rod?
Old Apr 15, 2011 | 06:43 AM
snobordboy's Avatar
Moderator
Default Re: Piston Rod
The H22a and h22a1 (should) have the same rods. Just check to verify both are the same diameter on the inside. If you can, match up the casting #, but that will affect your bearing size more than anything.
Old Apr 15, 2011 | 08:49 AM
Luded93's Avatar
I think the only difference is with the decks of the block. The connecting rods should be interchangeable. Like snobordboi said, check the diameters.
Old Apr 15, 2011 | 09:20 AM
Oh okay yeah because i find the h22a1 rods for sale everywhere but i have no luck finding the h22a..except at the dealer. Thats the other reason I was having doubts also..cause of the bearings..if they are interchangeable i should be able to use the ones i bought for the h22a rods in the first place right?
Old Apr 15, 2011 | 02:02 PM
gstrudler's Avatar
Are your h22a rods floating or press fit wrist pins? If you're using Honda bearings, it will be impossible to know which ones you need until you get the rod & have a machine shop check it & the crank.
Old Apr 15, 2011 | 02:04 PM
gstrudler's Avatar
Never mind, just saw you said 93-96 h22a, which is press fit, so the h22a1 rods should work
Old Apr 15, 2011 | 04:12 PM
they should? phew okay guess ill go ahead and get ahold of one of an h22a1 rod the..much easier to find for the meanwhile while i can get some aftermarket pistons..
Old Apr 16, 2011 | 10:26 PM
gstrudler's Avatar
FYI most aftermarket pistons are meant for floating rods, so you might have to get them bushed anyway.
ExplicitSpeed360
Sep 2, 2006 07:03 PM
hondasniper
Aug 12, 2006 07:36 AM
rawkus
Feb 16, 2005 02:57 PM
