Seized balance shaft can engine still run?
Old 05-02-2011, 07:37 AM
3s_rolla's Avatar
Default Seized balance shaft can engine still run?
hey guys i've been working on this car for the last month now and the car seems like its got a seized balance shaft. Is it possible to run the motor without putting the balance shaft belt back on? if so how will it run? or is there a way to remove it without having to buy an after market replacement for it? thanks.
-Doau
Old 05-02-2011, 07:48 AM
Moderator
snobordboy's Avatar
Default Re: Seized balance shaft can engine still run?
It will work just fine, just don't put the belt on. Many people run without balance shafts at all. I have been running with no belt on my current engine for 30-40K miles, and my new engine I did the full delete while building.
Old 05-02-2011, 07:52 AM
Luded93's Avatar
/\ like he said, just drop the belt. The only difference will be a slight vibration.
Old 05-02-2011, 12:33 PM
DCFIVER's Avatar
Originally Posted by Luded93
.. The only difference will be a slight vibration.
If that. I ran without my balance shaft belt for 5 years and did not notice any change in NVH at all.
Old 05-02-2011, 03:42 PM
minilogoguy18's Avatar
^It's a good bit more noticeable if you have some stiff mounts, like I have the ESP mounts and you can watch my steering wheel dance all over the place when not holding it. My rear balance shaft spun a bearing and locked up, been driving without a belt for a year with no belt.
Old 05-03-2011, 08:06 AM
3s_rolla's Avatar
ok thanks guys i'll let you know what happens. I wasn't sure if i could run this but thanks for the help guys.
Old 05-05-2011, 12:58 PM
slammedbbs's Avatar
isnt the alternator ran off that two?
Old 05-06-2011, 06:12 AM
97ludedude's Avatar
. . . NO . . . thats the crank pulley totally different. balance shaft belt is under the timing cover with the timing belt.
Old 05-07-2011, 06:54 AM
3s_rolla's Avatar
I got the car running and not a problem with it. no vibrations or anything. it runs great. thanks. guys
Old 04-30-2013, 08:01 PM
LoveMyAccord's Avatar
Hey so I have a 90 Accord w F22A4 engine. Like will my engine operate ok without the belt. the front balancer shaft is my oil pump. So would make it necessary to have belt. but if it is a electrical pump then it wouldn't need the belt right? the belt and pulley fell off the car while was running the front shaft where oil pump is, I was hoping no damage was done and that I could just remove the belt. If you know the answer to my question please help. thank you for your time.
92_civic
12-10-2008 06:30 PM
subydoored
03-24-2007 07:44 AM
rasta420
01-03-2007 10:05 AM
EGmikeH22
07-31-2005 04:53 PM
Neondog82
10-23-2004 01:04 PM
Quick Reply: Seized balance shaft can engine still run?
