Clutch Problems..
Old Apr 21, 2011 | 06:28 PM
Star's Avatar
Default Clutch Problems..
I have a 5 spd. 92 Prelude Si 4WS w/ H23a1. the clutch went out on it last month and i got it replaced 11 days ago. today going down the road i noticed the clutch started to catch lower and lower to the floor. eventually the clutch just stuck and went out. i didn't run the car hard AT ALL. could something be making it go out fast? i also replaced slave & master cylinder. Please help. Thanks
Old Apr 21, 2011 | 08:32 PM
PreludeMatt's Avatar
Default Re: Clutch Problems..
sounds like you're losing fluid somewhere along the way. follow the line all the way down. There's a spot above the transmission about halfway back there the hard line to the slave and the line from the master come together. Check to make sure that isn't leaking, I had it happen to me once
Old Apr 21, 2011 | 11:07 PM
ml21's Avatar
sounds like maybe who ever did your clucht didnt bleed they slave cylinder all the way if its stickin to the floor and you may have a leak check to see if the resouvir is low on fluid.
Old Apr 22, 2011 | 04:58 AM
Star's Avatar
i checked the fluid and its still at the max. i wonder if somehow a line could be clogged causing fluid not to go into the slave/master cylinder... i guess i just need to bleed the slave cylinder and see.
Old Apr 24, 2011 | 06:42 AM
Mr. Prelude's Avatar
I would recommend bleeding the clutch line. Air in the line can make a sloppy pedal.
acidburn2k2
Dec 1, 2017 02:31 AM
Tkrizz
10
Nov 6, 2015 10:20 PM
Civic Racer X 7
11
Aug 27, 2014 05:53 PM
JusAccord
Nov 7, 2011 05:51 PM
GraphiteMW
Mar 25, 2007 09:26 AM
