h22 q's
Old 03-08-2006, 12:36 AM
912's Avatar
Default h22 q's
i have an h22 can the crank out of a f- series work in the h22 block, if so do i re-use the h22 rods and pistons on f-series crank or do i use f-series crank, rods and pistons.By the way this is a 94 h22, or should i try to find a h22 crank. I'ts just that i have an f22a1 sitting in storage should i just use the f22 block or use f22 internals in h22, please help
Old 03-08-2006, 02:03 AM
antivic's Avatar
Default Re: h22 q's (912)
i might not ahve the numbers right, but i think that crank is a 97 mm crank, which is the same as the h23, u would probably be best off using h23 rods and h22 pistons...correc tme if i'm wrong,
Old 03-08-2006, 04:13 AM
RTFM
v4lu3s's Avatar
yeah you are right about the rods and crank.
need to use the f22 rods with the f22 crnak making the h22 into 2.3 liter engine.
Old 03-08-2006, 05:11 AM
Buffalo's Avatar
Default Re: (v4lu3s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">yeah you are right about the rods and crank.
need to use the f22 rods with the f22 crnak making the h22 into 2.3 liter engine.</TD></TR></TABLE>
yeap... but what about the rpm range?? I don't think you can rev the f22 crank safe as high as the h22 one...
Old 03-08-2006, 09:24 PM
912's Avatar
how is puttin the f22 not f23 crank in my h22a, makin it a 2.3 liter, ok so f22 crank and f22 rods will work, does the h22 pistons fit directly onto f22 rods. thankx
Old 03-08-2006, 09:37 PM
CGags13's Avatar
Default Re: (912)
...for the future plezze typ LEGIBLY so we can undeerrrrstand wat ur sayin so we can answer your questions
Old 03-09-2006, 12:10 AM
Rosko's Avatar
Default Re: (912)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 912 &raquo;</TD></TR><TR><TD CLASS="quote">how is puttin the f22 not f23 crank in my h22a, makin it a 2.3 liter, ok so f22 crank and f22 rods will work, does the h22 pistons fit directly onto f22 rods. thankx</TD></TR></TABLE>
the h22 pistons are bigger than the f22's thats how youre gettin to 2.3
f22 crank + f22 rods + h22 pistons = h23 vtec =
and yeah the pistons fit fine.
bigdaddyvtec
02-24-2012 03:54 PM
96ekdowork
08-01-2011 06:51 AM
2fastGSR
02-07-2010 08:09 AM
bleewdragon
11-15-2004 08:46 AM
honda13typer
04-27-2004 10:04 AM
Quick Reply: h22 q's
