Code 20: ELD
Old Mar 9, 2006 | 04:03 AM
DarkBB4's Avatar
Default Code 20: ELD
Hey after my swap, When i turn on the headlights, im getting code 20 and 7 (tps) which stands for ELD.. (headlights dont work, flashers dont, most electrical stuff goes haywire!) I have added a few grounds (thermostat to tranny ground) and (distributor to chassis ground) but i still have the problem. I was told that i should check out my fuse box (becuase i unplugged it awhile back) maybe i forgot to plug something in correctly...
Any help will be appreciated
Old Mar 9, 2006 | 10:32 AM
SteveoBA8's Avatar
Default Re: Code 20: ELD (DarkBB4)
Unbolt your under hood fuse panel and make sure the brown connector(on the bottom of the box) has a good connection and plugged in. Check out the flow chart i sent you.
Old Mar 13, 2006 | 04:36 AM
zeroice's Avatar
Default Re: Code 20: ELD (SteveoBA8)
sent pm, i have a code 20 also
Austin.em1
Jan 1, 2014 07:32 PM
usdm_ED7
Aug 30, 2011 09:30 AM
tubed-ef
Oct 18, 2008 08:22 AM
Brian_92GSR
Mar 25, 2005 11:33 AM
Mugen Dom
Nov 15, 2001 07:19 PM
