Problem with headlights not goin down
na really though. what did you do different from yesterday when they worked? work backwards. use a multi meter check if your getting power. check every fuse all over again. then let us know
thats wierd that they both quit. i remember my old 86 accord had a fuse for each light.
also there was a button you could push to keep them up when they were off, maybe the problem is there (if the prelude has one too)
if there is anything impeeding the assemblies from going up or down they will stay in the upright position. also, one thing you can also try is this; pull the manual adjustment **** of the adjustment pillar and turn it a little clockwize, then turn it back. this worked before on a 89 accord. you can also try and reset the ecu by pulling the main relay fuse for 5 minutes. i doubt this will be your issue though... hrmm there is a 3rd gen online manual in the 3rd gen faq section on preludepower.com or you can do a search there as well.
tuan...
Dec 15, 2006 03:32 AM
bitch
took you a while to comment about it. but j/p tho
