compression test........
Old Mar 6, 2006 | 12:47 PM
xd69's Avatar
Default compression test........
did a compression test on my jdm h22. i got the motor from HMO. this is how my test went:
cyl 1 200
cyl 2 200
cyl 3 200
cyl 4 210
i was doing some research and these numbers seem kinda low compared to other jdm h22's. i didnt hold it at WOT. will i see and increase if i do this? how can i get my numbers to go up?
thanks guys!
Old Mar 6, 2006 | 12:50 PM
iLude's Avatar
Default Re: compression test........ (xd69)
From what I've gathered, compression testers are not reliable to compare to other engines, as there are many factors that go into what the tester itself is going to read.
The most important thing is that all the numbers are close (within 10 or so) of eachother. In that aspect, you look good
Old Mar 6, 2006 | 01:59 PM
bb6prelude97's Avatar
those numbers don't sound bad at all
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iLude &raquo;</TD></TR><TR><TD CLASS="quote">
The most important thing is that all the numbers are close (within 10 or so) of eachother. In that aspect, you look good </TD></TR></TABLE>
well said
Old Mar 6, 2006 | 03:14 PM
Boarderx192's Avatar
Default Re: compression test........ (bb6prelude97)
Ya thats not to bad. Mine was 200 across all 4 on my H22a4.
Old Mar 6, 2006 | 07:44 PM
david1686's Avatar
Default Re: compression test........ (Boarderx192)
what are the normal numbers?
Old Mar 6, 2006 | 08:08 PM
xd69's Avatar
Default Re: compression test........ (david1686)
thanks guys.....im still a little confused. ok i know that what you are looking for is consistancy. but my buddy's h22a(same motor as mine) got 240 all across. does this mean that his motor his stronger(healthier) than mine?
Old Mar 6, 2006 | 08:30 PM
PrecisionH23a's Avatar
200-210 sounds okay. Do another test and hold it WOT. I bet you'll bump up the psi a bit.
Old Mar 6, 2006 | 08:32 PM
mnskateboarder's Avatar
Default Re: compression test........ (PrecisionH23a)
looks good
Old Mar 7, 2006 | 03:13 AM
accord03coupe's Avatar
where do i go the get a compression test, and how much is it cost?
i got a jdm h22a replace but it does feel any stronger than my old h22a4, some how i feel like the car slower then before.
thank
Old Mar 7, 2006 | 09:01 AM
SteveoBA8's Avatar
Default Re: compression test........ (accord03coupe)
You can buy one at a parts store, $20-40. Or take it to your tech and let him do it if your not mechanicaly inclined.
Old Mar 7, 2006 | 12:10 PM
Braco11's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xd69 &raquo;</TD></TR><TR><TD CLASS="quote">thanks guys.....im still a little confused. ok i know that what you are looking for is consistancy. but my buddy's h22a(same motor as mine) got 240 all across. does this mean that his motor his stronger(healthier) than mine?</TD></TR></TABLE>
yup, and he's a probably a better driver than you too. compression test numbers are like scales: i could weigh myself on various scales and get different results. your **** looks good and feels strong. now take some driving lessons and you'll be set.
ChronicGreenDC2
Jun 24, 2005 09:30 AM
snowblind7x
Apr 13, 2005 08:12 PM
top fuel
Nov 28, 2004 12:45 AM
2old_honda
Apr 12, 2002 01:25 AM
