MSD SCI on AEM EMS
Old Mar 9, 2006 | 08:33 PM
NewOrleansH22's Avatar
Default MSD SCI on AEM EMS
I have an ems on my h22 and i just found my old sci box in my room and did not kniw if it ***** with the ignition timing or if it is just an amp. Can/should i run it with the ems?
Old Mar 9, 2006 | 08:39 PM
PrecisionH23a's Avatar
Default Re: MSD SCI on AEM EMS (NewOrleansH22)
It does not mess with your timing. It amplifies your sparks.
Old Mar 9, 2006 | 08:46 PM
Default Re: MSD SCI on AEM EMS (PrecisionH23a)
so it can only help?
Old Mar 9, 2006 | 08:47 PM
In theory, yes. Sometimes certain EMS's don't get along with MSD units though... I would try and run stock ignition and if you experience break-up then throw the MSD on.
Old Mar 9, 2006 | 08:51 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">In theory, yes. Sometimes certain EMS's don't get along with MSD units though...</TD></TR></TABLE>
in a loss of HP kind of way or a break **** kind of way? Just quit my job so i am very paranoid about breaking **** untill i start my new job in 2 weeks.
I tried a search on this to no success?
Old Mar 9, 2006 | 08:52 PM
hu's Avatar
hu
You should be okay. I think PrecisionH23a has the best advice.
Old Mar 9, 2006 | 09:04 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NewOrleansH22 &raquo;</TD></TR><TR><TD CLASS="quote">
I tried a search on this to no success?</TD></TR></TABLE>
More of a break **** kind of way. MSD's tend to crap out on occasions and can lead to more problems actually.
https://honda-tech.com/zero...age=7
Check that thread out. Read pages 6 and 7 on what 'littlebluecrx' replied with. He gets into the ignition box discussion in pretty good depth. Personally, I fried 2 MSD boxes with my EMS and it also led to distributor problems. I switched to coil on plug with the aem cdi unit since.
If you are looking at staying under 400whp, stay with stock ignition. Maybe throw a better coil on there, some ngk blue plugs, 3330 spark plugs gapped to .24" Also, make sure you have enough grounds on the engine. I've also realized that good grounds are vital with the ignition not breaking up with higher horsepower applications.
Old Mar 9, 2006 | 09:14 PM
Turbo Lude SH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote"> I switched to coil on plug with the aem cdi unit since.</TD></TR></TABLE>
Sorry for being off topic, but could you possibly point me in the right direction for setting up a coil on plug ignition system?
Old Mar 9, 2006 | 09:28 PM
If you are looking at staying under 400whp, stay with stock ignition. Maybe throw a better coil on there, some ngk blue plugs, 3330 spark plugs gapped to .24" Also, make sure you have enough grounds on the engine. I've also realized that good grounds are vital with the ignition not breaking up with higher horsepower applications.</TD></TR></TABLE>
Ok so i think i am going to stay away from the msd and just get good coil. Cant afford to take chances.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo Lude SH &raquo;</TD></TR><TR><TD CLASS="quote">
Sorry for being off topic, but could you possibly point me in the right direction for setting up a coil on plug ignition system? </TD></TR></TABLE>
Would there be any benifit to this with a fully built NA engine. I would like to know where to get a coil on plug setup. I saw it on an h22 on a forum about a 2 years ago.
TopEndUSA
Apr 22, 2007 04:58 PM
lupin5
May 23, 2005 06:36 PM
PrecisionH23a
Mar 17, 2005 10:00 AM
shermanyang
Sep 15, 2004 05:49 PM
