suspension help
Old Mar 6, 2006 | 08:19 AM
bb4ninja's Avatar
Default suspension help
I recently ordered some tokico struts and springs, but i am not sure how to install them, since i have never done this before. Is there some kind of write up on this? i already searched the suspension area, please help
Old Mar 6, 2006 | 08:38 AM
NvrSlowsDown's Avatar
It is pretty simple but if you have to ask you should probably have someone else do it. And you will need a spring compressor.
Basically you jack up the car and take off the bolts on the bottom of the strut, the brake lines on the strut and the three bolts on the top of the strut. Then take out the strut and put the spring compressor on it and take off the top nut on the strut. Then install everything in the reverse order you took it out.
Old Mar 6, 2006 | 09:03 AM
bad-monkey's Avatar
http://www.ntpog.org/mods/fift...shtml
moistmildred
Jun 27, 2014 07:16 PM
benin360
Nov 3, 2011 01:49 PM
reeder321
Nov 26, 2008 06:05 PM
Trumpster
Jul 10, 2004 06:57 AM
Saboteur
Sep 19, 2001 09:30 AM
