Caster Plates
Old Mar 9, 2006 | 10:29 AM
vinuneuro's Avatar
Default Caster Plates
Does anyone make caster plates for our cars?
Old Mar 9, 2006 | 10:34 AM
The_Sober's Avatar
Default Re: Caster Plates (vinuneuro)
I know what a camber plate is, and I know what castor wheels are...
help me out, bruh. what's a caster plate?
Old Mar 9, 2006 | 10:37 AM
vinuneuro's Avatar
Default Re: Caster Plates (The_Sober)
err....can camber plates help with adjusting caster? Could I add camber plates to the top of the strut towers, then slide the struts to achieve desired caster? Would that work?
Old Mar 9, 2006 | 10:48 AM
117's Avatar
117
No. Camber and caster plates only work on cars with McPherson struts. The Prelude is a double wishbone / multilink setup (at least the 2Gen through 5Gens are).
Old Mar 9, 2006 | 11:02 AM
vinuneuro's Avatar
Default Re: (117)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 117 &raquo;</TD></TR><TR><TD CLASS="quote">No. Camber and caster plates only work on cars with McPherson struts. The Prelude is a double wishbone / multilink setup (at least the 2Gen through 5Gens are). </TD></TR></TABLE>
Thanks man. Looks like I'll have to get the shorter radius rod from Honda after all.
Old Mar 9, 2006 | 11:06 AM
syntax.'s Avatar
Default Re: (vinuneuro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinuneuro &raquo;</TD></TR><TR><TD CLASS="quote">
Thanks man. Looks like I'll have to get the shorter radius rod from Honda after all.</TD></TR></TABLE>
why not just use a few washers if you want to change the caster?
Old Mar 9, 2006 | 12:20 PM
vinuneuro's Avatar
Default Re: (syntax420)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by syntax420 &raquo;</TD></TR><TR><TD CLASS="quote">
why not just use a few washers if you want to change the caster?</TD></TR></TABLE>
The SH's radius rod isn't threaded at the subframe end:
http://www.hondaautomotivepart...SH%29
Old Mar 9, 2006 | 12:37 PM
syntax.'s Avatar
i was thinking about a 4th gen, my bad
Old Mar 9, 2006 | 02:34 PM
yOnKiNaToR's Avatar
maybe he wants an increase in caster. adding washers only decreases caster. to increase caster you'll have to either slot the bolt holes on the front subframe and adjust it, or cut the front radius rod bushings.
Old Mar 9, 2006 | 02:54 PM
SnlpeR's Avatar
if you get the ingalls camber kits where it replaces the upper control arm bushings...
you can do weird things to the upper control arm position...like give it a ton of caster and such
Old Mar 9, 2006 | 03:53 PM
vinuneuro's Avatar
Default Re: (SnlpeR)
Right now, it seems like my two options are between the shorter spec rod Honda sells to adjust caster and some kind of camber kit. Most of the camber kits just seem to be adjustable ball joints.
Old Mar 21, 2006 | 02:22 PM
yOnKiNaToR's Avatar
do they have any shorter radius rods for 4th gens? I've lost a lot of caster due to my new ES radius rod bushings.
tangou
Sep 27, 2007 06:20 PM
watsvtecEK
Mar 12, 2006 07:54 PM
junlude19
Mar 17, 2005 04:53 PM
lDanny
Apr 26, 2004 11:46 AM
Vtecfool
Jul 31, 2003 11:55 AM
