engine problem? maybe?
Old Jun 13, 2007 | 08:53 PM
airetam's Avatar
Default engine problem? maybe?
Hi guys! I'm a first timer here and I've looked at all forums already trying to find one that related to mine. By the way, I have a 5 gen. lude.
What happened was that I took it out to race and I miss my shift (it was my first time racing -__-) and went past redline in 2nd gear. I was at about 7700 - 7800 before I went to third gear. After the run, I pulled over and noticed that my car was bogging. I didn't think it was a vacuum problem because it idled okay. I thought it was my spark plugs because I also smelled fuel from my exhaust so I replaced it with some NGKs. That didn't solve the problem. It sounds like it's pinging, but i'm not quite sure because when I let my engine idle, I can hear it at sometimes and then it just disappear. I thought it could be my knock sensor, but it didn't set CEL. When I shut off my car, it farts. The sound doesn't go away at high speeds. Any advice?
Old Jun 15, 2007 | 12:54 PM
Lewdin' Incognito's Avatar
Default Re: engine problem? maybe? (airetam)
If you truly misshifted, which it sounds like you did, you could have one or more bent valves.
Compression test and leakdown test would let you know.
Old Jun 15, 2007 | 12:58 PM
nonvteclude's Avatar
Default Re: engine problem? maybe? (Lewdin' Incognito)
^^that was my guess. if no valves are bent try to adjust the valves.
Old Jun 19, 2007 | 08:18 PM
airetam's Avatar
Default Re: engine problem? maybe? (nonvteclude)
What are the worst consequences of having bent valves?
Old Jun 20, 2007 | 06:58 AM
Rob97'SH's Avatar
Valves, Valve guides , Piston damage, head damage , cams snapping , springs broken ect,.
Extreez
Aug 26, 2006 11:16 AM
meagainsttheworld
Apr 15, 2006 08:08 AM
SexyAzNMami
Mar 17, 2005 12:25 AM
psilo
Sep 29, 2004 12:20 PM
accord00turbo
Jul 20, 2002 01:14 PM
