engine hesitation
Old Jun 14, 2007 | 12:31 PM
92H23VTEC's Avatar
Default engine hesitation
I recently changed the cam seals and when I went to drive it hesitated real badly. I thought maybe one of the cam gears were off a tooth, but they werent. So then I checked the timing and it was dead on, but it still seems like the timing is off. So I experimented with the timing and it has gotten a little bit better, but still not back to normal. Im just wondering if there is something else it could be that I haven't checked. Thanks in advance!!
Old Jun 14, 2007 | 12:43 PM
nonvteclude's Avatar
Default Re: engine hesitation (92H23VTEC)
did you mess with the distributor/plug wires?
Old Jun 14, 2007 | 12:51 PM
mattsnooz's Avatar
Default Re: engine hesitation (nonvteclude)
yeah, sounds like distributor
Old Jun 14, 2007 | 02:26 PM
92H23VTEC's Avatar
Default Re: engine hesitation (mattsnooz)
I didnt mess with the distributor, but when I had a buddy time it he did in order to get the timing in the correct spot using the light. But that didnt help. LoL. But since then I have messed with the distributor and it has gotten better, its just still not rite. I have just moved it a lil by lil and then drive it and see how it runs. I just dont know why it didnt run well when the timing was supposed to be right on.
Old Jun 15, 2007 | 07:31 AM
fabe85's Avatar
set it fully advanced and see if that helps, if so . check ur o2 and injectors.
bnmm
Engine Management and Tuning
May 27, 2011 05:28 AM
98r410
Jan 23, 2007 05:16 AM
GaRn
Feb 5, 2006 07:10 PM
NWAS
19
Oct 19, 2005 12:17 PM
krazn
Feb 22, 2004 11:11 AM
