ABS light
Old Jun 11, 2007 | 07:00 PM
prelude_93vtec's Avatar
Default ABS light
hey. my brakes werent workin about a year ago. i got them fixed and they work fine, but my abs light is on. when i start the car, its not on but after a while it turns on. anyone know the problem?
Modified by prelude_93vtec at 12:41 PM 6/15/2007
Old Jun 11, 2007 | 07:03 PM
nonvteclude's Avatar
Default Re: ABS light (prelude_93vtec)
i had the same problem awhile ago it ended up being that the passenger side abs sensor got loose. worth a try
Old Jun 11, 2007 | 07:06 PM
Default Re: ABS light (nonvteclude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvteclude &raquo;</TD></TR><TR><TD CLASS="quote">i had the same problem awhile ago it ended up being that the passenger side abs sensor got loose. worth a try</TD></TR></TABLE>
where is it exactly located?
Old Jun 11, 2007 | 07:09 PM
on the back side of the spindle housing right next to the axle. there will be a black wire coming from the bay and down the suspension. there will be one for all 4 brakes
Old Jun 11, 2007 | 08:14 PM
HondaB18's Avatar
Did you check the brake fluids?
Old Jun 15, 2007 | 11:40 AM
Default Re: (HondaB18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaB18 &raquo;</TD></TR><TR><TD CLASS="quote">Did you check the brake fluids?</TD></TR></TABLE>
ya but i think when the brake fluids are low, the brake light goes on not the abs light.
Old Jun 15, 2007 | 11:55 AM
mattsnooz's Avatar
Default Re: (prelude_93vtec)
wheel speed sensors probably. each tire has a speed sensor.
Old Jun 15, 2007 | 06:38 PM
street_ride14's Avatar
Default Re: (mattsnooz)
Jump your service plug to Pinpoint the problem. Search "ABS code"
dc4-b20
Suspension & Brakes
Sep 25, 2008 04:57 AM
Steezn4NOReason
Nov 3, 2004 09:22 AM
Turboz
Sep 27, 2004 04:50 AM
metal-x
Jan 27, 2004 10:01 AM
RyanAutry
May 3, 2003 02:23 PM
